1360 by 768 via hdmi
Discussion in 'LCD & LED LCD TVs Forum' started by fxytimi, Sep 13, 2007.
Tags:
  1. fxytimi
    fxytimi
    Apr 2, 2007
    157
    +9
    i hooked my PC up to my LXD70 via and i am only getting 720 by 1280 720p, so i have to stretch the resolution to get it full screen, and u have a x1950 pro. with VGa however i can get 1360 by 768, does any one else have this problem. ?
  2. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,008
    +265
    I'm pretty sure this is a restriction of the display standards used in the HDMI ports. I think they're designed to only use the specific TV resolutions, i.e. 1920x1080, 1280x720, 720x576, etc.
    1360x768 is a PC-specific resolution & there is your problem...
  3. fxytimi
    fxytimi
    Apr 2, 2007
    157
    +9
    oh right i see, are all TV's like that, as hdmi can only input 720p 480p 1080p and etc, or is it just the LXd70?
  4. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,008
    +265
    I would think most TVs are like that, although I'm only really experienced with the Panasonics in that department...
  5. Naqv
    Naqv
    Oct 15, 2006
    3,645
    Birmingham
    +355
    I also can't output at 1366 x768 via HDMI. However, there is a method of outputting at 1366x768 if you have a nvidia card, where you can create custom resolutions.
  6. fxytimi
    fxytimi
    Apr 2, 2007
    157
    +9
    seems like ima have to buy a VGA, yay. as i thought hdmi was better so i went for hdmi i was wrong. daaam :(
  7. mikl1984
    mikl1984
    Apr 20, 2007
    383
    43
    Moscow Russia
    +107
    It's question of right EDID
    Samsung R8 and LG support 1360x768 via HDMI without problems
    You may check all supporting modes of your TV via moninfo programm
    http://entechtaiwan.net/util/moninfo.shtm
    Sample of report from Samsung R8
    Code:
    Monitor
    Windows description......... Generic Monitor
    Manufacturer description.... SAMSUNG
    Manufacturer................ Samsung
    Plug and Play ID............ SAM029D
    Serial number............... n/a
    EDID data source............ I2C bus (real-time)
    Manufacture date............ 2006, ISO week 45
    EDID revision............... 1.3
    Display type and signal..... Digital
    Sync input support.......... n/a
    Screen size................. 160 x 90 mm (~8")
    Power management............ n/a
    Color characteristics
    Display gamma............... 2,40
    Red chromaticity............ Rx 0,632 - Ry 0,357
    Green chromaticity.......... Gx 0,289 - Gy 0,596
    Blue chromaticity........... Bx 0,143 - By 0,085
    White point (default)....... Wx 0,280 - Wy 0,290
    Timing characteristics
    VESA GTF support............ Not supported
    Horizontal scan range....... 15-50kHz
    Vertical scan range......... 49-71Hz
    Video bandwidth............. 90MHz
    Extension blocks............ 1
    Timing recommendation #1.... 1360x768 at 60Hz
    Modeline................ "1360x768" 85,500 1360 1424 1536 1792 768 771 777 795 +hsync +vsync
    Timing recommendation #2.... 1280x720 at 60Hz
    Modeline................ "1280x720" 74,250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
    Timing recommendation #3.... 1280x720 at 50Hz
    Modeline................ "1280x720" 74,250 1280 1720 1760 1980 720 741 746 750 +hsync +vsync
    Timing recommendation #4.... 1920x540 at 60Hz
    Modeline................ "1920x540" 74,250 1920 2008 2052 2200 540 542 547 562 +hsync +vsync
    Timing recommendation #5.... 1920x1080 at 30Hz
    Modeline................ "1920x1080" 74,250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
    Timing recommendation #6.... 1920x540 at 50Hz
    Modeline................ "1920x540" 74,250 1920 2448 2492 2640 540 574 579 562 +hsync +vsync
    Timing recommendation #7.... 1920x1080 at 25Hz
    Modeline................ "1920x1080" 74,250 1920 2448 2492 2640 1080 1148 1158 1124 interlace +hsync +vsync
    Timing recommendation #8.... 720x480 at 60Hz
    Modeline................ "720x480" 27,000 720 736 798 858 480 489 495 525 -hsync -vsync
    Timing recommendation #9.... 720x576 at 50Hz
    Modeline................ "720x576" 27,000 720 732 796 864 576 581 586 625 -hsync -vsync
    Standard timings supported
    640 x 480 at 60Hz - IBM VGA
    720 x 400 at 70Hz - IBM VGA
    720 x 480 at 60Hz - Samsung
    720 x 576 at 50Hz - Samsung
    800 x 600 at 60Hz - VESA
    1024 x 768 at 60Hz - VESA
    1280 x 720 at 50Hz - Samsung
    1280 x 720 at 60Hz - Samsung
    1360 x 768 at 60Hz - Samsung
    1920 x 540 at 50Hz - Samsung
    1920 x 540 at 60Hz - Samsung
    1920 x 1080 at 25Hz - Samsung
    1920 x 1080 at 30Hz - Samsung
    Raw EDID base
    00: 00 FF FF FF FF FF FF 00 4C 2D 9D 02 00 00 00 00
    10: 2D 10 01 03 80 10 09 8C 0A E2 BD A1 5B 4A 98 24
    20: 15 47 4A A1 08 00 01 01 01 01 01 01 01 01 01 01
    30: 01 01 01 01 01 01 66 21 50 B0 51 00 1B 30 40 70
    40: 36 00 A0 5A 00 00 00 1E 01 1D 00 72 51 D0 1E 20
    50: 6E 28 55 00 A0 5A 00 00 00 1E 00 00 00 FD 00 31
    60: 47 0F 32 09 00 0A 20 20 20 20 20 20 00 00 00 FC
    70: 00 53 41 4D 53 55 4E 47 0A 20 20 20 20 20 01 1D
    Raw EDID extension (CEA-861)
    00: 02 03 1A F1 46 84 13 05 14 03 12 23 09 07 07 83
    10: 01 00 00 66 03 0C 00 20 00 80 01 1D 00 BC 52 D0
    20: 1E 20 B8 28 55 40 A0 5A 00 00 00 1E 01 1D 80 18
    30: 71 1C 16 20 58 2C 25 00 A0 5A 00 00 00 9E 01 1D
    40: 80 D0 72 1C 16 20 10 2C 25 80 A0 5A 00 00 00 9E
    50: 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00 A0 5A 00 00
    60: 00 18 8C 0A D0 90 20 40 31 20 0C 40 55 00 A0 5A
    70: 00 00 00 18 00 00 00 00 00 00 00 00 00 00 00 69
    EIA/CEA-861 Information
    Revision number............. 3
    DTV underscan............... Supported
    Basic audio................. Supported
    YCbCr 4:4:4................. Supported
    YCbCr 4:2:2................. Supported
    Native formats supported.... 1
    DTV formats supported....... 6
    CE standard timings supported
    1280 x 720p at 59.94/60Hz (16:9) - HDTV (Native)
    1280 x 720p at 50Hz (16:9) - HDTV
    1920 x 1080i at 59.94/60Hz (16:9) - HDTV
    1920 x 1080i at 50Hz (16:9) - HDTV
    720 x 480p at 59.94/60Hz (16:9) - EDTV
    720 x 576p at 50Hz (16:9) - EDTV
  8. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    What about Sony sets, do they accept 'PC signals' via HDMI or do I have to send 'video signals' instead?
