Loofah
Established Member
I'm starting to look at a new laptop or 2in1 and getting nowhere. I've found in the past that the windows 13.3" laptops have suited me just fine so figured I'd stick with that. Budget would be around £500 and I'll not be using it for anything strenuous although some work on InDesign or Illustrator is possible.
Is there anything reasonable out there or should I revise my expectations a bit?
