12volt remote trigger (2.5 to 3)
Discussion in 'Cables & Switches' started by cameronl, Sep 24, 2004.
  1. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    hi there all, I have an Arcam A32 intergrated which accepts a 3 (cm?) diameter trigger and a Halo A52 poweramp which accepts a 2.5 (cm?) diameter trigger. While the Halo came with a 2.5 to 2.5 this is no good to me.
    I really don't want to mess around with it either as i'm sure i'll be using it one of these days. So, with that in mind, does anyone know where i can buy a remote trigger cable with 2.5 at one end and 3 at the other?
    thanks for your time.
    CaM
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Do those connectors look like small headphone plugs? Then it's 2.5 and 3.5mm - adapters should be available from most hifi stores.
  3. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    oh, its that simple is it :)
    so all I need is a 2.5mm and a 3.5mm head phone jack and some bellwire...
    thanks for your help.
    CaM
  4. Brian110507
    Brian110507
    Yes but are they Mono or Stereo - do they have one coloured band around the 'pin' or two.
    incedentally 2.5 cm is one inch - don't think their that big.
  5. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    er, I'm not sure I'll have to check :)
    CaM
