12v TV for motorhome
Discussion in 'LCD & LED LCD TVs Forum' started by Pete Delaney, Aug 28, 2005.
Tags:
  1. Pete Delaney
    Pete Delaney
    Mar 14, 2005
    3,212
    Lincolnshire
    +653
    Hi folks,
    Can anyone recommend a good size tv that will accept a 12v power supply. I see plenty on pricerunner and other sites but they do not state whether a 12v input is part of the spec. I have yet to buy the said motorhome....but it should happen over the next 4 weeks or so :clap:
  2. saint123
    saint123
    Feb 6, 2005
    57
    Technofan, I've just bought a 17" widescreen Mikomi from Argos for £229...
    It operates on 12v DC...It comes with a 240v adaptor for home use...Hope
    this helps
  3. Pete Delaney
    Pete Delaney
    Mar 14, 2005
    3,212
    Lincolnshire
    +653
    Excellent, sounds like it might be a standard feature? Thanks! :thumbsup:
    Pete.
  4. Rob1698
    Rob1698
    Many small screens run on something like 16V that is supplied from an external adapter.
    However, you should always be careful when connecting some other than the intended supply.
    In a motorhome the supply voltage may vary more than what the external adapter would provide, and the TV may not be able to handle the variation, the voltage spikes, etc.
    I think in specialized shops you will be able to buy specially designed supplies that take the battery voltage and convert it to a stable 12V or 16V source to be used for electronic equipment like an LCD TV, a laptop, etc.
    (without going via 230V. that of course is also a possibility, but with a lower efficiency)
  5. mjcairney
    mjcairney
    Oct 26, 2003
    7,133
    2
    2
    137
    Airdrie, Scotland
    +984
    Hi there - most good caravan accessory shops sell what you're after.
    Cheers,
    Martin.
