12v Trigger on 3805
Discussion in 'AV Receivers & Amplifiers' started by punkjr, Oct 29, 2005.
  1. punkjr
    punkjr
    Does anyone know how to make the 12v trigger work when the 3805 is fired up? I need it to turn my Rotel 1070 amp on when the 3805 is switched on.
  2. Jase
    Jase
    Mar 16, 2001
    10,960
    United Kingdom
    +3,435
    You have to assign the Triggers to the correct Zone and Input. It's done via the Option Setup Menu from the Main OSD. Just select ON for the Inputs you want. Check the manual under Setting the Trigger Out Setup, it tells you how to do it.
  3. punkjr
    punkjr
    ok, i thought that, the way i read the manual, you can assign trigger 1 for dvd and trigger 2 for say a cd player. i wasn't aware that you could select all in the list. thanks. my 3805 should arrive on monday, can you tell me if it comes with the 12v trigger cable/lead?
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Mine didn't.
  5. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    24,000
    2
    The Fylde Coast
    +14,009
    Nor mine.
  6. punkjr
    punkjr
    what type of shops sell them, hifi?
  7. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I would imagine a decent shop stocks them or would be able to get them made up for you...
  8. punkjr
    punkjr
    is it just a 3.5 stereo plug similar to what one would find in a computer shop
  9. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    24,000
    2
    The Fylde Coast
    +14,009
    Looks like it to me.
