12v trigger for pj screen
Discussion in 'Projectors, Screens & Video Processors' started by NickBull, Dec 7, 2001.
Thread Status:
Not open for further replies.
  1. NickBull
    NickBull
    Does anyone have one? I quite like the idea of the screen coming down as the pj is switched on, do they work well or are the tempramental?
    I assume the barcos have 12v triggers.
    How much are they?
    Nick
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I'm afraid the Barco doesn't have a 12volt out. the most reliable is to use the 18volt which powers the iris.
    I'm working on a simple box that will make this possible.
    Most of the comericial ones that would be suitable are about £350
  3. NickBull
    NickBull
    OUCH! That's a bit steep!
    Mine doesn't have an Iris, would that be a problem?
    Nick
  4. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    hiya ive just got a remote control system from http://www.direkt2u.co.uk/ this includes a baby 3 button remote and eye sensor and the box with the brains in it ,it was £150 delivererd ,i thought of having a trigger but the thought of wires across the room put me off ,,i have set up a macro in the pronto pro so in a round about way it does the same thing..
    goodluck ......
  5. NickBull
    NickBull
    Cheers, that was a consideration.
    I may just leave it, I don't have a pronto so I'd probably end up leaving the screen down unless it did it all on one button press!
    At the moment I keep it down, just though it might be cool to have it automated!
    I suppose an interface with a PC might be quite good, when I turn on the HTPC the screen comes down!
    Nick
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Does it not do a 12v out through a 9pin/RS232 port?
    We make little boxes to patch into these for srceens etc.
  7. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I'm not an RS232 expert but I don't think any of the voltages are a high as 12volts.
    As I said the only voltage I am aware of that comes close whilst the projector in operation is the 17 / 18 volt rail. this is only available when the PJ is running. This is on the Comm 800 port.
    There is no external 12 volt supply from a Barco projector
  8. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Roland: Whatever it is we do a box to modify it. It works on the Cine series gear anyway so should work on the rest too.
Thread Status:
