12v trigger connections
TributeAle
Established Member
Using two power amps with processor, is it better to use two 12v trigger connections on processor, one to each amp, or connect one amp trigger to the processor and the second using the trigger out on the first amp ie daisy chain?
Bippu
Established Member
I am trying to understand 12v triggers. Exact same thing really. Did you get a solution ?
Do you have to continually send the voltage to keep it on and cut in the voltage switches off ?
Spielberg, Shyamalan, Aronofsky, Chazelle, Eddie Murphy and Mel Gibson - all the latest movies
