12v Power Station
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by niccam, Jan 1, 2004.
  1. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Hi can any one advise me if a 12v portable power station is any good for my 12v video camera [which uses a 12v lead acid battery ] using a suitable lead ,have already used one those Yusa lead acid rechargable batteries so far no problems. Just afraid of votage problems too high, burn out circuts,etc Thank you niccam
  2. Brian110507
    Brian110507
    by 12volt power station do you mean a mains operated device or the ones which you recharge and carry about and often have large cables to jump start a car. If the latter then they are only a 12V battery put in a fancy box and will give no more voltage than the Yuasa you have been using, I often use one to run my camcorder via the cigarette - um accessory plug which these power packs also have. Should be OK.
    But if a mains powered device just get someone with a voltmeter to measure it's output on load some of these do have poor regulation and on a light load like a camcorder may give a bit more voltage, but a plate on your camcorder should tell you what the safe maximum is, it is often more than the rated voltage.
  3. niccam
    niccam
    Apr 16, 2002
    239
    16
    N. IRELAND
    Thanks Beejaycee, yes its the portable ones not mains.
    Yours niccam
