1280x720 from pc to sagem hd d50 g4t
fizzgog
hi guys, what graphics card would i need for my pc to display 1280 x 720 on my sagem hd d50 g4t? also, what connections should i use?
thanx in advance
pete
currently my moniter resolution goes upto 1024 x 768
S
s-bravia
if you want to output 720p signal, then i would recommend you to output via HDMI port cause its made for outputing 720p.
So get any graphic card with DVI out (then u need DVI to HDMI cable) or HDMI output would do.
fizzgog
thanx for the response bravia. ive just found out in another thread that my pc will only accept pci graphics cards which are not good enough to handle HDTV :(
cheers
pete
Podcast: Philips OLED+935 impressions, Denon AVC110 Review, Film Reviews, News and More...
