120v Player in UK?
Rom
You would need a stepdown transformer. Available at places such as Maplin. Check the wattage the player needs and get a transformer that is slightly higher rated. Ususally for a HD/BD/DVD player a 100w one will suffice. Prolly cost about £15.
Greggles
Established Member
When it comes to step-down transformers, I have always used the Tacima range, which despite the name is actually made in the UK (Ilford!) available from:
http://www.tlc-direct.co.uk/Main_In.../USA_110volt_Convertor_Transformer/index.html
They are rather unusual looking, due to the use of superior toroidal coils, which results in the cylindrical shape.
The 100VA mode would be more than adequate for your needs. Incidentally, these were (informally) recommended to me by Russ Andrews.
alienandy
Established Member
Thanks for that. I have bookmarked that page and as you recommended it I will probably go for that one.
Many thanks for this. Much appreciated.
:smashin:
Amazon Fire TV Cube Gen 3 Review: Coming Soon
