120MB HDD 7200rpm in SKY+
Discussion in 'Sky Digital TV Forum' started by Mouth on Legs, Jan 28, 2003.
  1. Mouth on Legs
    Mouth on Legs
    Jan 10, 2003
    77
    anybody put one of these in their sky+ box any any problems. 5400rpm 120Gb HDD are a rather rare comodity so I was wondering if anybody has sucessfully used a faster dive. Where I live we get frequent powercuts so a drive which the box wont recognise after a powercut is no use to me
    On a slightly different isuse, what would happen if you were to switch the power on after a cut, give the disk time to spin up (but assuming too slow for the box to reconise it, then do a quick power off/on so the disk had not stopped spinning and would therefore power up quicker: would this work???
  2. Timmy B
    Timmy B
    I ordered the 5400 version from dabs two days ago where there was 12 instock and 100s in 1-3 days.
    My HD is now in the post.
    WHY IS EVERYONE SAYING THESE ARE RARE!!!!
  3. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    I had a Maxtor DiamondMax9 120GB, 7,200RPM drive in my Sky+ box now for about three weeks and have not noticed any problems as yet and it does not seem to get any hotter than the old Maxtor 5,400RPM drive that came out.
    I did however leave off the top part of the drive holder inside the Sky+ box to allow for better heat dissipation.
    Cheers, Lee
  4. Rookies
    Rookies
    Jan 4, 2003
    4,900
    103
    +345
    I too cant understand why people say it rare to get hold of 5400rpm HD.
    There were shed loads at manchester computer fair on saturday when i went
  5. Mouth on Legs
    Mouth on Legs
    Jan 10, 2003
    77
    Ok so not rare anybody able to answer my other question about spin up time?
  6. Steve1138
    Steve1138
    see http://www.avforums.com/forums/showthread.php?s=&threadid=64459 (my last comment in that thread)
    have had a 120 GB 7200 rpm disk in since Xmas.
    No prob with initial installation... started up first time, just follow std installation instructions. There are a few others with 7200 MAXTOR disks who also reported no probs.
    I don't believe the spin up time is an issue anymore.
    New Disk seems to work with the jumper set to either Master (first one on the left) or Cable Select (2nd from left)... which is what my orig disk was set to... so not sure if it makes any difference which you use
    Steve
