120gb OCZ Vertex 3 vs 120gb Samsung 840 Basic
Discussion in 'Computer Components' started by codered01, Mar 5, 2013.
  1. codered01
    codered01
    Nov 19, 2011
    13
  2. s1mon
    s1mon
    Apr 10, 2012
    52
    get 240gb if budget allows i have OCZ 240gb and its good! unless you are shifting lots of data you wont really notice the speed difference between the two. I use mine for photoediting so have two in raid 0 and lots of storage (6tb) when im done editing.
    120gb is ok for os and a few games but these days fills up quick!
  3. dacads
    dacads
    Jul 24, 2009
    1,379
    Peterborough
    +155
    Samsung is more reliable as the OCZ used Sandforce controller which is known for having issues. Although the OCZ does have better write speeds...difficult choice really :p
  4. Harry Clayworth
    Harry Clayworth
    Feb 25, 2013
    24
    3
    I have the Samsung 256gb ssd and i cannot praise it enough (i upgraded from and old 250gb samsung 54,000 rpm hdd) my programs open up almost instantly, i haven't had any slow downs or crashes either.
    My system takes about 18 seconds to boot up now compared to my old drive that took about 60 seconds (both drives had the same amount of data on it). I definitely recommend the samsung, and if you can stretch your budget to 256gb i would (I'm sure i had an email from ebuyer the other day with the 256gb on offer for £124.99).
  5. Xareh
    Xareh
    Dec 2, 2012
    128
    +19
    Woah. Dude. Keep that drive. Seriously.
    Samsung 840 SSDs are absolutely phenomenal. I've heard OCZ uses artificial benchmarks to make it look like they're better. Somebody once said they upgraded to an 840 Pro from a Vertex 3 RAID 0 array - that's insane!
  6. Drudgery
    Drudgery
    Mar 17, 2013
    3
    In this case I'd certainly go for the cheaper drive. In terms of performance and reliability you won't notice too much difference between the two drives. The basic Samsung 840 series have a very good reputation amongst mainstream consumers (i.e. us) so I'd go for that drive.
  7. RustySpoons
    RustySpoons
    Jan 1, 2007
    1,064
    South Wales
    +167
    I'd go for a Samsung 830 over a 840 basic, the 840pro is something else though :)
