1100mm wide three shelf cantilever stand advice
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Rottie, Aug 17, 2013.
  1. Rottie
    Rottie
    May 1, 2007
    925
    46
    +135
    Hi all,
    I'm going to be upgrading my aging HC setup (see sig) to either a Onkyo TX-NR818 or a TX-NR616 (Depending on which one my local RS has in stock, when I go there tomorrow) and a set of Wharfdale DX-1HCP's.
    Currently, my TV stand is 1100mm wide, with three shelves, the bottom one with approx 350mm clearance.
    I'm looking, if possible to get a cantilever stand approximately the same dimensions, but haven't seen anything nice in black and would appreciate any links/pointers. :) Budget is not really important, but ideally <£300. :thumbsup:
    Also, what length screws would I need to mount the screen on the cantilever? I'm almost positive they're M8's, but I have no idea on the length required. :facepalm:
    Any help / advice is more than welcome and appreciated. :)
