10Mtr USB is there such a thing??
Discussion in 'Desktop & Laptop Computers Forum' started by newstuart, Jul 27, 2004.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,675
    Northumberland
    +59
    Guys i am in need of a usb lead that is approx 10-12 m long and cant find one anywhere,is there such a thing if so anyone know where ??
  2. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
  3. Paul Alamo
    Paul Alamo
    Max size of USB is usually 5M but you can buy repeaters, they are like leads with single port hubs on the end. I have one but is does not work consistantly sometimes you have to re-insert the plug to get it to detect the device on the other end. Perhaps newer devices are better.
  4. HMHB
    HMHB
    Nov 11, 2001
    25,561
    Nottinghamshire
    +3,894
    As Paul says, if you go over 5M you can have problems. It might be worth trying a repeater though, but it depends what you are going to stick on the end of the usb cable I think.
  5. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    FWIW, I have a 5 metre USB extension into which I have plugged a USB/PS2 convertor and on the end of that there is a mouse and keyboard.
    Total length is about 7.5m and it works fine.
  6. newstuart
    newstuart
    Apr 22, 2004
    1,675
    Northumberland
    +59
    Thanks for the advice,basically the set up i have involves a
    media center pc in my office and plasma set up in living room,The plasma runs SVGA from the pc and at present im using a IR booster to control media center.What I would like to do is run a usb cable from pc to living room (approx 10-12m cable run),this would mean the IR reciever for the pc would hopefully be much more reliable than it is now (ie about 50% hit rate!) plus i would be able to add a hub at the end of the extension lead to conect a keyboard of digi camera quickly and surf net or watch pictures directly from living room.I know i can get a cordless keyboard but I tried a RF one and it was useless as there are 3 walls between the rooms(probally explains why IR repeater doesnt work either.
  7. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    Is there no way of relocating the media PC so it is either in the lounge or closer to the plasma?
    I moved my PC from one end of the study to the other and shortened the run by about 3 metres so I was able to get away with a 5m USB cable.
  8. newstuart
    newstuart
    Apr 22, 2004
    1,675
    Northumberland
    +59
    Afraid not,I allready moved my office around to get the shortest run possible (ie pc right against wall,hole drilled through 2 further walls to living room) and as i work from home also having pc in living room just wouldnt be practical which was initally my other idea.Think I may just bite the bullet and by 2 leads with the extender and hope for the best,its just alot of money and hassle if it wont work
  9. Brogan
    Brogan
    Oct 9, 2003
    7,476
    +481
    It should only be about £10-£15 to see if it works.
    My 5m USB extension was about £4 from Ebay (Quay Computers).
  10. newstuart
    newstuart
    Apr 22, 2004
    1,675
    Northumberland
    +59
    well I guess ill go down this route unless I can find a different option,its not so much the money more the hassle of routing through the walls etc but ill give it a go thanks alot guys
  11. HMHB
    HMHB
    Nov 11, 2001
    25,561
    Nottinghamshire
    +3,894
    I've a feeling you'll struggle to put a hub on the end of that length and still get reliable connections, but hopefully you will prove me wrong ;)
