10m HDMI Cable with Bush BFSAT03HD. Picture Problems.
Discussion in 'Satellite TV, Sky TV & FreeSat' started by nezero, Mar 3, 2013.
Tags:
  1. nezero
    nezero
    Mar 3, 2013
    As the title suggests, I am using a 10m HDMI cable with a Bush BFSAT03HD box, connected to a little 22" Bush HD led TV.
    Every now and then and then the HDMI signal appears to get interrupted and the screen goes black for a few seconds. Though every component appears to work fine.
    At first I thought it was the cable, as with a shorter cable it was fine. Though when testing the cable with other devices, it works well.
    I plugged the box into a network to try and update it, it says the it running v2.02 but I cannot find confirmation that this is the latest version. Software update has options auto or manual but cannot see any way to manually do an update! Any help?
    I have read other posts that have issues with 10m cables and PC`s, and the issue seems to be with power delivery. These boxes run off 12v power supply (transformer in the plug).
    Does anyone have any ideas for me to try and resolve this issue?
    Thanks.
