Question 10m HDMI 2.1 Cables?
djgibbon
Hey all
As per title really - having a new house wired up in the next few weeks and need a 10m HDMI run. Looking to future proof as much as possible but can't find any legitimate looking cables which support 2.1. Is it just too early for them to be on the market or am I looking in the wrong places?
Phil
mushii
If you want future proof, then forget about the cables and install some 22mm conduit, so that you can replace the cables whenever you want.
At 10m your best bet is to install some fibre optic hybrid HDMI’s such as RuiPro’s. (Other hybrid fibre optic cables are available)
djgibbon
Cheers mushi. Yes, I'm getting conduit put in but not having done it before I was wary of how easy it would be to actually pull cables through!
Fibre optic is what I was leaning towards but I was surprised nothing was ultra high speed certified.
Joe Fernand
AVForums Sponsor
HDMI cables are not version compliant - there is a separate system of 'Category Speed' Certification which applies to cables.
At present the High Speed and new Ultra High Speed Certification process only applies to passive cables - so there is no way to 'Certify' an Active Copper, Fibre or Hybrid Fibre HDMI cable.
Joe
djgibbon
Ah, now that _does_ make sense - I was lazy with my phrasing saying 2.1 and meant Ultra High Speed, but didn't realise it only applied to passive cables. Thanks!
Is there any feeling whether fibre optic cables have more bandwidth headroom for 2.1, or would that be meaningless conjecture?
Joe Fernand
AVForums Sponsor
You have to focus on the Features you require support for and identify if the cables you are considering will support them - eARC being the big unknown at present as for now it is mostly something you can only test in a lab and not real world systems.
Moving forward there is a new generation of '8K' capable cables to consider.
RuiPro4K (which we supply) - are well established as a good solution with current generation of kit and have been (bench) tested to support eARC.
RuiPro8K Hybrid Fibre - are available, to order, the one problem being it is very difficult to 'prove' how they are going to work in the real world at present.
Ideally you ensure any cable you install now can be easily replaced at a later date.
Joe
djgibbon
Thanks Joe, straight up and honest answer. To be honest it's eARC and dynamic HDR which are the main concerns for me - I don't see me having a need for 8k any time soon. Decent size conduit and a fish wire seem like the best future proofing I can manage!
Phil
dajusta
Hi Joe, do you have a link to your product that ships to Canada? The only place I found your cable is on Amazon US and I don't normally order from there.
Also got a discount code? :)
Similar threads
