10m Component cable issues
Discussion in 'Cables & Switches' started by Tim.Lad, Aug 26, 2005.
  1. Tim.Lad
    Tim.Lad
    May 30, 2005
    Rossendale Valley
    +6
    I’ve got a problem that’s been bugging me for weeks…
    The problem I get when watching films on my projector, during very fast moving and bright scenes I will lose the picture for a few seconds while the projector trys the find the input again, as if the component lead was unplugged for a split second.
    My setup comprises of several RGB devices that go into a switch box then onto a active splitter one output goes to an RGB to component converter then to the projector, the other straight into a TV..
    I have eliminated everything and discovered the problem lies in a 10meter component cable….
    My question is this cable to long ? does it need boosting or do I need a much higher grade cable ?
    Regards
  2. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    10M is nothing compared to what componant video can do!
    When you say you have eliminated everything, how have you done this?
    It would suprise me that this would be down to the cable...
    The fact the input is being lost says to me that the syncs are being lost on the Y channel. Have you tried swapping either the R-Y or B-Y with the Y lead? The syncs only apeer on the Y, and you will still get a black and white pic with just the Y plugged up... Try this and see of you still loose the I/P.
    Gareth.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,763
    The Borders
    +3,088
    Tim.Lad
    Do you have a short 3RCA to 3RCA cable you can use as a 'control' to prove all works fine with YUV into your Projector?
    Best regards
    Joe
  4. Tim.Lad
    Tim.Lad
    May 30, 2005
    Rossendale Valley
    +6
    I will try this tonight thanks
  5. Tim.Lad
    Tim.Lad
    May 30, 2005
    Rossendale Valley
    +6
    yes i found a scene on a DVD that caused the problem and conected straight to the converter then to the project useing a crappy 1 meter 3RCA lead i had and it worked fine reconected it to the other end of the 10 meter lead and it fails...
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,763
    The Borders
    +3,088
    Hello Tim.Lad
    Just to confirm you have tested:
    Source > RGB Switcher > RGB Splitter > RGB Converter > 1m YUV cable and all works fine?
    Joe
  7. Tim.Lad
    Tim.Lad
    May 30, 2005
    Rossendale Valley
    +6
    yes
    Actually correct that I tested without the switch box and amp…
    Source > RGB converter > 1m cable > projector = works fine
    Source > RGB converter > 10m cable > projector = fault happens
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,763
    The Borders
    +3,088
    Hello Tim.Lad
    Just wanted to confirm I had followed your last post :)
    So the problem can either be the Output of the Converter not having enough voltage to 'drive' a 10m cable (unusual) or the Cable - which Converter and Cable are you using?
    Joe
  9. Tim.Lad
    Tim.Lad
    May 30, 2005
    Rossendale Valley
    +6
    i`m using a JS tech converter and a generic (cheapo) cable :( i feel ashamed...
  10. Tim.Lad
    Tim.Lad
    May 30, 2005
    Rossendale Valley
    +6
    OMG I finally figured it out!! .. After fiddling with the cables as Gareth suggested i decided to tidy the cables around the switch box and the 3RCA lead going to the projector since then it been working perfectly!!! i can only assume that one of the other cables near by was interfering with the projector cable...
    Thanks for you help guys
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,763
    The Borders
    +3,088
    Hello Tim.Lad
    Good that you got sorted - though I'd suggest a replacement 10m cable as your is definitely lacking in shielding (or has a dodgy solder somewhere) if the picture gets affected/knocked out by what's next to it.
    Best regards
    Joe
  12. Tim.Lad
    Tim.Lad
    May 30, 2005
    Rossendale Valley
    +6
    to be honest a got a broken Toshiba MT5 project of my mate for £100. and managed to repair the power supply, i was just being a bit cautious and not spending a fortune on cables when it could go at any time...
