Quantcast
Question 10m cable required for subwoofer, advice required
j1mgg
I am currently changing my setup and moving it from a dedicated room to a not so much dedicated room, and this requires me having the subwoofer located alot further from amp.
In the old room i just used a 3m cable i was given by richer sounds when i purchased my speakers, but now with the new placements, and hiding of cables, the new lead will need to be close to 10m long. What should i be looking for
Van Damme Blue Ultra Subwoofer Cable 10 Metre Length | eBay
Ixos XHK506 PC-OFC Gamma Geometry Subwoofer Cable Kit 9m - Special Offers - AudioVisual Online - Home Cinema and Hifi Specialists
https://www.amazon.co.uk/Fisual-10m...482826530&sr=8-2&keywords=10m+subwoofer+cable
It will be connecting a yamaha rx675 to a monitor audio mass w200 if that makes any difference
Marshall Mike
While a lot of people have different views on how much should be spent on cables, the sub cable is important as you don't want the cable picking up any interference. With that in mind, don't go with the Fisual cable as it's not double shielded. I would advise to spend what you are happy with without scrimping.
FWIW, I bought this cable a couple of weeks ago and I'm very happy with it:
Fisual Havana Custom Made Subwoofer Cable - By Brand - AudioVisual Online - Home Cinema and Hifi Specialists
adam-burnley
I recently got one of the Fisual 10m cables from Amazon and it's fine. Fits tightly and is thicker than the cable I got from Richer Sounds originally, so feels better. I'm not an audiophile though so not sure if that makes a difference, but my SW still sounds good.
Violator
I use the IXOS one, it's well made and it's also pretty thin and flexible. Works great.
j1mgg
Thanks for the replies so far, will probably have to ditch the ixos one as 9m is just not going to be enough.
Have seen another cable on here being recommended alot(van dammed studio) and made to measure by Mark someone, so will have a good look at that aswell.
Think £20 point is what I would be willing to pay.
Marshall Mike
I think you will struggle to get a semi decent 10m cable for £20, you might want to up that budget a wee bit ;)
Marshall Mike
This was the one recommended in a few other posts, how much better would the canare be for double the price, would it be twice as good, or only a small but better?
Van Damme Subwoofer Cable with Neutrik Rean RCA connectors - Mark Grant
There is a very good chance you probably wouldn't be able to tell the difference between the two cables when listening, so, as long as that cable doesn't pick up any interference you will be fine. My only concern would be it doesn't mention if it's double shielded or not, but that might not even matter in your system. As I said before, spend what you are comfortable with as everyone has differing views. Adam said he uses the Fisual cable (single shielded) without any problems after all.
Why don't you buy it and try it, you can always return it if there's a problem ;)
MemX
Similar threads
