10m cable recommendations
Discussion in 'Cables & Switches' started by andimac101, Sep 18, 2005.
  1. andimac101
    andimac101
    I have recently purchased a sanyo z3 pj. I have connected my dvd and freeview to it at the mo with standard s video and component cables, the picture quality is - lets just say, not very good.
    I want to connect both up over 10m with some fairly good leads and dont want to break the bank (under £100 for both unless I would REALLY notice the difference !)
    I would also like to know if it would be better to use some kind of junction box and have just the one component lead connected as apposed to the s video and the component for each device- if so where would i find such a junction box ?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,270
    The Borders
    +2,572
    andimac101
    What Outputs are available on your two source devices and do you have an AV Receiver with video switching on-board?
    Best regards
    Joe
  3. andimac101
    andimac101
    The outputs I have are-
    Freeview= scart only
    DVD= S video, RGB scart and component
    I dont currently have an AV receiver
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,270
    The Borders
    +2,572
    andimac101
    Tricky one!!!
    If you hadn't mentioned budget I'd have suggested:
    Replace the Freeview for one with YUV out on SCART - SRP £90.00 (see http://www.iplayer.co.uk/index1.asp)
    Add a JS Technology Master Component controller - SRP £50.00.
    Add a 1m VanDamme SCART to 3RCA cable - approx £40.00.
    Add a 1m VanDamme 3RCA to 3RCA cable - approx £30.00
    Add a 10m VanDamme 3RCA to 3RCA cable - approx £50.00
    Best regards
    Joe
