10m between source and display
Discussion in 'Cables & Switches' started by S Helton, Nov 30, 2004.
  1. S Helton
    S Helton
    Oct 29, 2004
    52
    Hi Guys
    In order to comply with my wifes aesthetic requirements in our lounge, I need to place my source equipment (DVD recorder and freeview box) around 10 metres from the display. As a compromise, I get a new LCD display :cool:
    The DVD will be connected via component, and the freeview box via RBG scart. Will the 10m run cause me any problems ? I am mainly concerned about any loss of picture quality, as serious viewing will have the audio going through an amplifier.
    I am willing to invest in some decent quality or custom made cables - any suggestions of suppliers also welcome.
    Thanks.
  2. xavk1
    xavk1
    Aug 9, 2004
    559
    28
    +36
    I too have just undertaken such a re-design of my setup.
    I moved my amp, players etc 10m (as the cable runs) round the lounge from the Z2 PJ. I used a Mark Grant component cable (compared to a decent £50 1m component cable from Seven Oaks). I have not noticed any degredation in picture quality at all (it is possibly marginally better).
    http://www.avforums.com/forums/showthread.php?t=104551
    Only slight warning is that Mark's component cable is not small - approx 2cm across the girth, so make sure you can live with that (on my display, the pictures in the thread are smaller than the cable is in real life!).
