10ht+Denon2800="HELP"
Discussion in 'Projectors, Screens & Video Processors' started by laurie, Dec 6, 2001.
  1. laurie
    laurie
    Nov 23, 2001
    145
    16
    Sydney Australia
    Guys
    has anyone with this combination managed to set it up using Avia the setting for contrast can go all the way up to 100 on the white test patten and still can see the moving bars!!
    worse still the denon 2800 has its own settings so how do you first calibrate the denon contrast,bright,sharp,gamma, that is supposed to be used to calibrate the 10ht....if its out then the pj will not be correct but if I use my normal tv to calibrate the denon where do I put it settings to!! I give up
    cheers Laurie
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    You should be able to both the black and white moving bars.
    I would leave the Dennon on it factory settings unless you can not achieve the correct settings on the projector.
    Make sure the IRE setting on the dennon is set to 0 rather than 7.5
  3. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi laurie dont mean to offend but are you sure you are going the right way with the settings on my sanyo plv30 i had to lower the contrast with my denon!!!!
    if you still have problems try emailing paul cavelle he has that combi
    jason
