10GB networking issues
Puntoboy
Not quite sure what you mean by the keystone reference, or could be a termination issue.
If you have a bad connection you can get port flapping when the connection speed changes between the different levels. The MikroTik ones will tell you if there is this the issue
On the patch panel, you don't terminate the individual wires into the punch down connector, you terminate into a standard RJ-45 connector and plug that into the back of the panel.
Haven't seen any errors relating to port flapping :)
Puntoboy
I've decided to just replace the patch panel as I could use this one elsewhere where 10GbE isn't needed. So I've ordered a slightly different style this time. It's essentially just a plate with holes for the keystone jack to connect to. I've also ordered some CAT6a jack plugs for it.
Amazon product
Amazon product
neilball
Could be poor connection via the keystones - crimping plugs is often more difficult than punch-down blocks. More than one company I’ve dealt with would only allow termination via lunch-downs for that reason. The only way to be certain would be to test with a 10Gb-capable certification tester, but these are pretty pricey!!
Puntoboy
Not sure I quite agree that crimping is more difficult than punch-down, I've certainly never had a problem with either over 15 years in IT :)
Anyhow, the new keystones are punch-down type rather than the passthrough type on the existing patch panel.
D
Deleted member 24354
I never understood passthrough patch panels. Terminating structured cables in RJ45 plugs is self defeating as they cannot be certified, as the standard requires that they are terminated into IDC type connectors. They also add another mechanical connection into the chain. Am I missing something? BTW this isnt a flippant comment its a genuine question.
Puntoboy
For home it's ideal, changing cables around etc. is a doddle.
Puntoboy
Tbh when I ordered it, I thought it was going to be a different style. It's actually no easier than the new style I've ordered.
Puntoboy
New patch panel installed and most of my connections swapped over. I didn’t order enough keystones so more coming tomorrow.
Puntoboy
I should also add, I like the tool less keystones. They are fairly easy to fit. Although tool less is a bit of a stretch. I found it far better to use a pair of grips to clamp the cover down onto the wires and terminals.
I shuffled the connections around so the PoE devices are on the PoE end of the switch and vice versa. I am also still seeing 10GbE speed from my PC to the NAS in the garage connecting through the Aggregation switch.
D
I agree, I fitted about 20 this weekend on an install. I ended up having to use my Krone Tool to to push cables into some of them
Puntoboy
I found my Krone tool made the job harder as there is little space in these connectors (yours might be different). Once I had all of the wires in the plastic backplate and pushed into the keystone it just needed a little grip squeeze to get them to seat.
D
Tight is an understatement. It want the initial fitting, it was when I was testing each cable I found that I had pairs that weren't connected and I had to go back and re-punch those cables with my Krone Tool
mickevh
Love the LED's in your rack...! Do they animate at all...? If would be so cool if they dissolved between colours over time or ran a light chase like some 80's disco rope light.
Is 8K TV dead? Philips OLED+907, Pioneer LX505 AVR plus B&W 700 S3 Reviews & Visit + AV/HiFi News
