1080p via vga
THE BOARS
hi can i connect my panasonic viera and 360 via vga for 1080p or is it too much for my telly its the older version [1.5 yeras old]
DD3
I strongly suspect not. probably the best you can connect at will be the 1376x768 which is probably the resolution of your TV. best thing to do is check your manual, set the xbox to the resolution of the panel and see what happens. ;)
