1080p swordfish problem
Discussion in 'Xbox Forums' started by spadge, Mar 22, 2006.
  1. spadge
    spadge
    has any of u guys managed to get this streaming through the xbox360 ive tried hdtv2mpeg but no joy any ideas its the first film what hasnt streamed cheers spadge
  2. Mike@Portugal
    [email protected]
    Feb 5, 2004
    95
    Maputo
    AFAIK 1080p is only supported in WMV not in .TS files, even then 1080p is downconverted to whatever resolution you are using in Xbox 360
  3. spadge
    spadge
    are you sure it doesnt play 1080p in ts file
  4. Pooon
    Pooon
    Dec 26, 2002
    7,543
    Canterbury, Kent
    +1,186
    I don't think the 360 outputs/supports 1080p, only 1080i
  5. DarkEntity
    DarkEntity
    Feb 13, 2005
    2,584
    2
    137
    Glasgow
    +606
    The only options on the 360 are 720p and 1080i
  6. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    The 360 does not like some 1080P WMV files, it will play the batman 1080P Trailer Fine, will not play the Alexandra 1080P trailer and Stretches the TAxi 3 1080P Trailer
  7. emporer
    emporer
    Mar 10, 2005
    8,236
    +1,626
    it will play 1080p ts files but obviously downconvert to the appropriate level
  8. Mike@Portugal
    [email protected]
    Feb 5, 2004
    95
    Maputo
    One thing is playing 1080p, a very diferent thing is outputting 1080p.
    Xbox 360 plays WMV 1080p and does not play 1080p MPEG2 (.TS)
    Xbox 360 does not output 1080p, instead it downconverts 1080p to whatever resolution is in like 720p or 1080i ou others.
    I too have some 1080p WMV that don't play anymore, but they did in the early days of my Media Center PC, i still didn't find out what is the problem, they simply say "FINISHED" after i press Play.
  9. Mike@Portugal
    [email protected]
    Feb 5, 2004
    95
    Maputo
    Are you sure about that?
    I recall seeing that it only supports 1080i MPEG2 in www.xbox.com and now i cannot find that info, damn... i will keep looking.
  10. Mike@Portugal
    [email protected]
    Feb 5, 2004
    95
    Maputo
    FOUND IT! :thumbsup:
    Here it is: http://forums.xbox.com/1005870/ShowPost.aspx
  11. emporer
    emporer
    Mar 10, 2005
    8,236
    +1,626
    maybe i was wrong, although i do remember watching my copy of matrix reloaded which was 1080p via my 360, it could have been my linktheater but i am pretty sure it was my 360
    dunno tbh :)
  12. spadge
    spadge
    yeah ive got matrix reloaded which is 1080p ts and that works a treat
    so im stumped
  13. raymondo1
    raymondo1
    Apr 11, 2005
    609
    28
    +88
    ive played back 1080p material no problem (ts files).
    obviously down samples, but it plays them.
    and they look great :)
  14. Mike@Portugal
    [email protected]
    Feb 5, 2004
    95
    Maputo
    Well, i don't know, i have lots full movies in .TS but none of them are in 1080p, damm, i will have to download some, they must be great even downconverted to 1366x768 :D
    Spadge,
    Try do deinstall HDTVPump and install nero mpeg-2 decoders or ffdshow and tell it to decode Mpeg-2, works great, i don't have HDTVPump.
  15. spadge
    spadge
    nero mpeg-2 decoders or ffdshow how do you use these? im used to hdtv2mpeg any ideas?
    spadge
  16. Mike@Portugal
    [email protected]
    Feb 5, 2004
    95
    Maputo
    Just install ffdshow and go to the video codec configuration and change mpeg2 codec to libavcodec.
    If the .ts doesnt play just rename them to .mpg
    Another alternative is installing Nvideo Purevideo codec or install Nero that install the Nero Video Codec
