1080p HDCP problems
Discussion in 'Xbox Forums' started by I Spiritus I, Mar 4, 2013.
  1. I Spiritus I
    I Spiritus I
    Sep 17, 2010
    4,549
    Scotland
    +933
    Hello guys,
    Wondering if you can help me a bit as I seem to be at a loss.
    I currently have my Xbox 360 set to 1080p output but the screen seems to flicker and go funny colours etc. I've also noticed strange lines appearing on the screen too. I've also noticed I can't now play videos from Xbox Video due to there not being a HDCP connection. (Bare in mind this has always worked before going straight to my 1080p TV and 1080p capture card (At the same time via a splitter and directly plugged in to each device)).
    I thought that this could have just been a cable issue, so changed the cable but the problem is still there. The funny thing is that I can play the xbox at 720p with little problems however it has happenned occasionally at 720p.
    Any ideas? Just worried my Xbox is on the way out! I have the 120gb Elite.
    Cheers,
    S.
  2. majnu
    majnu
    Feb 14, 2009
    15,087
    UK
    +3,534
  3. I Spiritus I
    I Spiritus I
    Sep 17, 2010
    4,549
    Scotland
    +933
    Thanks Maj, I'll give them a check later.
    I have not tried a different TV only the two (Capture is picked up as one & the TV itself). Will try hooking it up directly to the PC monitor though and see. Yeah I have tried a reset of the settings however it did not work :(.
