1080P Full HD TV does this mean your watching in HD
Discussion in 'Satellite TV, Sky TV & FreeSat' started by paul777, Mar 1, 2013.
  1. paul777
    paul777
    Dec 24, 2009
    290
    +8
    1080P Full HD TV does this mean your watching in HD on all channels? As I can see the picture a little sharper when I watch a Sky HD channel but it isn't a vast difference.
  2. John
    John
    Dec 13, 2002
    11,620
    +3,279
    Sky is only 1080i or 720p . You only get 1080p from Bluray or Download on Xbox/PS3 or such like
  3. paul777
    paul777
    Dec 24, 2009
    290
    +8
    So I am not watching all channels in HD or Sky for that matter!!!
  4. logiciel
    logiciel
    Feb 2, 2008
    53,118
    UK
    +5,765
    That depends on what you mean by "in HD"!
    Sky machines, and specific satellite TV channels and programmes, give their level of HD; BRs give theirs which are usually better, and there are others.
  5. paul777
    paul777
    Dec 24, 2009
    290
    +8
    What I was basically wanting to know was what am I getting picture quality wise watching a channel that is not HD! with a Full HD TV compared to a TV that isn't Full HD.
    Thank you in advance.
  6. logiciel
    logiciel
    Feb 2, 2008
    53,118
    UK
    +5,765
    That depends again;), this time on what the TV does with the SD programme it receives.
    Some TVs will "upscale" it, in some cases to a resolution of your choice.
  7. paul777
    paul777
    Dec 24, 2009
    290
    +8
    This is a minefield where would I find out if it upscales?
  8. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,169
    Er no. :facepalm:
    All HD tvs will upscale an SD picture, if they didn't it wouldn't fill the screen.... SD is 720 x 576 and full HD is 1920 x 1080.
    What you probably mean is that some STBs can upscale, such as the Sky box or Bluray player. In this case the device does the scaling so the TV doesn't have to. You'd only do this if the scaler in the device is better than the TVs. When the Sky box resolution mode is set to Auto the scaler is off and the TV will do it, otherwise you can choose 720 or 1080. If your TV is half decent set it to auto, otherwise try the others.
  9. logiciel
    logiciel
    Feb 2, 2008
    53,118
    UK
    +5,765
    I probably did mean that.:D
    My new Onky upscales anything it gets to a resolution of choice.:)
  10. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    And then if necessary your TV upscales/downscales the picture to the screen's resolution if you have not chosen the "correct" resolution.
  11. paul777
    paul777
    Dec 24, 2009
    290
    +8
    So is there a chance of me breaking my tv? I have just set Sky box to Automatic.:confused:
  12. kevkbuk
    kevkbuk
    Jan 27, 2011
    5,988
    +1,169
    No, worse that'll happen is the picture is scaled twice with loss of picture quality. Auto is the right setting fr the Sky bx if your TV is decent. There's a lot of marketing BS and miss undertanding of scaling unfortunately.
  13. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,493
    Redditch
    +4,171
    You won't break anything, any mismatch between the number of pixels in the signal and the screen will be corrected by the TV. Incidentally no broadcaster uses 720p all satellite is 1080i usually at 1920 x 1080 (Freeview-HD has some 1080p25 content so it's not true that you can only get 1080p from blu-ray). On a full-HD TV receiving such a signal no scaling is required as you have the same number of pixels in the signal as on the TV. Some processing is required to to show a interlaced signal on a progressive display but scaling isn't required.
  14. paul777
    paul777
    Dec 24, 2009
    290
    +8
    Ok thanks I wish I asked this sooner don't know why Sky only do 1080i they could have released 1080p with the new software or am I wrong?
  15. logiciel
    logiciel
    Feb 2, 2008
    53,118
    UK
    +5,765
    The p would need more bandwidth and they're already cutting back on that.
  16. paul777
    paul777
    Dec 24, 2009
    290
    +8
    Really as they are offering 6 months free unlimited, and channel 4 is coming on demand I am confused. I thought they would be expanding for on demand etc.
  17. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,493
    Redditch
    +4,171
    1080p25 actually needs less bandwidth than 1080i as progressive content compresses more efficiently, this is the reason many say Freeview-Hd has better pictures than satellite. 1080p can't be used on satellite because the boxes don't support it. Freeview T2 HD boxes were designed to be 1080p25 capable from day one but can't do 1080p50.
  18. paul777
    paul777
    Dec 24, 2009
    290
    +8
    Great explanation. thank you Graham.
  19. logiciel
    logiciel
    Feb 2, 2008
    53,118
    UK
    +5,765
    I stand corrected then, though others have made the same mistake previously.
    If 1080p did come into use no doubt machines that could handle it would be easy to produce.
  20. paul777
    paul777
    Dec 24, 2009
    290
    +8
    True why are they not doing it then is Graham wrong?
  21. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,493
    Redditch
    +4,171
    You would have to replace millions of existing boxes, Sky, Freesat generic fta ones. Can't see it happening just to get relatively small savings in bandwidth and a small increase in picture quality. 1080i50 and 1080p25 isn't dramatically different. Freeview changes dynamically between the two, it caused a few problems with some TV's when it was introduced.
    BBC Begin Broadcasting In 1080p - News - Trusted Reviews
    All Freeview-HD channels now use 1080p25 and 1080i.
  22. paul777
    paul777
    Dec 24, 2009
    290
    +8
    I know what you're saying Graham but you would think they would do it to new boxes just going out and phase the old ones with 1080i out, or even just the new 2TB HD boxes. Just a thought.
  23. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,600
    Oxford
    +1,335
    It is a chicken and egg situation - manufacturers are unlikely to change (if costs are higher) until broadcasts are being made to use it and broadcasters are unlikely to change until there is a significant proportion of boxes capable of viewing it. It is far more likely that neither will ever bother as Ultra HD is now on the horizon.
  24. paul777
    paul777
    Dec 24, 2009
    290
    +8
    Good point lets hope they make the broadcasts and the boxes are made to recieve Ultra HD, other wise what is the point.
  25. logiciel
    logiciel
    Feb 2, 2008
    53,118
    UK
    +5,765
    And the TVs are made to display from the "boxes".:)
  26. paul777
    paul777
    Dec 24, 2009
    290
    +8
    We can only hope.:)
