New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
Hi, ive got an optoma hd20 projector. Whenever i use 1080p the picture randomly flashes white! If i use 720p, the picture is fine. My hdmi lead is 10m long.(dont know if that makes a difference).
Any ideas??
m
Any ideas??
m
I know that people had problems with cheaper quality hdmi which are of a long length. Might be useful to try it out with a different hdmi lead if you have one spare or can borrow one.
The first 10 metre HDMI cable I bought would only pass 720p or 1080i. I spent a bit more on the second (still only around £50 IIRC) for one spec'd as 1080p. I've since run 1080/60p (the highest data rate we currently have) and it worked fine. I'm about to try sending 12 bit 1080/50p or 1080/24p soon, so I hope my cable is upto this (the cable is buried under the floor and in the walls now ).
You can buy a HDMI booster/equalizer. In fact I'm looking for one (just to be on the safe side, plus I need to slightly extend my HDMI cable as I've moved my projector to the top of a bookcase and it only just reaches. If anyone knows where I can get a HDMI 1.3 capable equaliser I'd be happy to know where.
The best bet is to plug in a shorter lead to test it. If it does it on another lead then it's not the lead. But it probably is the lead, I had a cheapy one that made all the colours jumble up on screen.
