1080p all in one?
Discussion in 'Home Cinema Buying & Building' started by akasmiler, Jan 24, 2008.
  1. akasmiler
    akasmiler
    Oct 3, 2007
    1,933
    48
    +44
    after major looking around and deciding i was gonna go with the sony Dav IS10 but then i found out it was only 1080i and not p so...........
    what systems out there do 1080p and any recomendations
    the missis has capped me at £600:rolleyes:
  2. YellowSphere
    YellowSphere
    Dec 2, 2007
    4,448
    103
    +471
    Don't get hung up on this 1080p business. Most of the time upscaling in the screens is better than in the DVD players anyway.
    If the IS10 is the right system for you, get it, and don't worry about the fact it's "only" 1080i.
  3. buzlightyear
    buzlightyear
    Oct 8, 2002
    960
    46
    London
    +119
    Im more miffed that the IS10 isnt Blu Ray. Anyone know if Sony will do a BR version of this.
  4. Chilly Willy
    Chilly Willy
    May 25, 2006
    380
    +75
  5. Chilly Willy
    Chilly Willy
    May 25, 2006
    380
    +75
    This might be what you want:
    http://www.askdirect.co.uk/uview?cal...Search&id=9967 :smashin:
  6. akasmiler
    akasmiler
    Oct 3, 2007
    1,933
    48
    +44
  7. Chilly Willy
    Chilly Willy
    May 25, 2006
    380
    +75
  8. akasmiler
    akasmiler
    Oct 3, 2007
    1,933
    48
    +44
  9. akasmiler
    akasmiler
    Oct 3, 2007
    1,933
    48
    +44
  10. akasmiler
    akasmiler
    Oct 3, 2007
    1,933
    48
    +44
    also just noticed that the sony dav-is10 also doesn't have HDMI inputs
  11. YellowSphere
    YellowSphere
    Dec 2, 2007
    4,448
    103
    +471
    Most all in one systems don't have HDMI inputs, the only one-box system I know of with inputs is the Pioneer LX-01.
    The sound from the PS3/Sky HD can be sent to the IS-10 with digital cables, with the HDMI cables taking the video to the TV as normal. You'd need either an optical to coaxial adapter or optical splitter, however, since the IS-10 doesn't have two optical inputs. Same as the 850, and most things that you'll be looking at, to be honest.
    However, it may be worth you going for something which is just the amplifier unit and speakers, since you can use the PS3 for DVD playback. There are some Sony systems that do this for very reasonable money, though I think there are some new ones on the way with more features for HDMI Audio. Someone may be able to fill in the gaps on that.
  12. Chilly Willy
    Chilly Willy
    May 25, 2006
    380
    +75
    First vision:
    I would have a guess and say that your tv has only one HDMI input. If so you could use this to link your ps3 and sky hd and hts to your tv HDMI input.
    http://www.amazon.co.uk/HDMI-Tri-Link-Switcher-PS3/dp/B000NJZRSI/ref=pd_ecc_rvi_1
    I am using this one at present.
    Now for audio:
    To link your ps3 and sky HD and possibly your tv to your HTS you could use this if any or all have Digital Audio Outputs.
    http://www.kenable.co.uk/product_in.../1013?osCsid=78b3d3517d692b6cf6243928c10bd975
    I am also using this at present with my system.
    I hope this has helped you.
    Will :thumbsup:
  13. Welsh Whirlwind
    Welsh Whirlwind
    Mar 15, 2006
    1,890
    +262
    Just get yourself a Sony HTD-870RSF £499.00 or HTD-870RSS £429.00(satellite speaker version) and 'wollop' all your needs covered, amazing connectivity and a 160gb HDD recorder to boot. Laughing.
    I've one of these systems and they're an absolute aural delight.
    System HERE
    My Review HERE
  14. Chilly Willy
    Chilly Willy
    May 25, 2006
    380
    +75
    :D What's this "All Singing, All Dancing" but wait what is this I read NO USB port :eek:, my! oh! my! oh! my! how can I listen to my Ipod or watch my Divx movies from my external HDD :rotfl:
  15. Welsh Whirlwind
    Welsh Whirlwind
    Mar 15, 2006
    1,890
    +262
    Chilly, read the post.
    The HTD-870RSF has a USB 2.0 port on the HDRX870 recorder. :suicide:
    Whats with the sarcastic replies??
  16. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    moving to LCD's.
  17. Welsh Whirlwind
    Welsh Whirlwind
    Mar 15, 2006
    1,890
    +262
    Fox, it's only Norris's post above that is out of context! Otherwise the post starter was looking for an all in one that upscaled to 1080p.
    Any chance it can be moved back?? :smashin:
  18. Welsh Whirlwind
    Welsh Whirlwind
    Mar 15, 2006
    1,890
    +262
    Bump
  19. akasmiler
    akasmiler
    Oct 3, 2007
    1,933
    48
    +44
    somebody appears to have made a boo boo
    anyway, i'm now considering a denon avr - 2308 with kef kht 2005.2 speakers for £800:smashin:
  20. C225
    C225
    May 15, 2006
    6,290
    Linlithgow
    +785
    Moved back to the correct place (i think) :D
  21. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    yeh,i made a booboo,and moved the whole thread,instead of a single post.
    out of practise i think..:rotfl:
  22. Chilly Willy
    Chilly Willy
    May 25, 2006
    380
    +75
    :oops: Sorry Welsh just my Irish sense of humour :suicide:
  23. Welsh Whirlwind
    Welsh Whirlwind
    Mar 15, 2006
    1,890
    +262
    No worries CW, it's all good.
    Cheers. :thumbsup:
