1080i vs 720p source, Panasonic plasma
Discussion in 'Panasonic TVs Forum' started by 147jk, Feb 10, 2009.
  1. 147jk
    147jk
    Jan 28, 2009
    19
    Hi all. I just purchased a 42" Panasonic TH-C42HD18 plasma. Really nice TV, except for one thing. I see a huge difference in the picture quality between a 720p source and a 1080i source. Using a 1080i source, the picture is unbelievably clear. On the 720p source, the picture is "HD", but not really all that great. The odd thing is that with my older Philips 37 LCD (37PF7320A/37BV), I see no difference between the 2 sources (they are both crystal clear).
    Am I missing something? Why would an older Philips LCD behave differently than my brand-new Panasonic? Do I not not have this TV set up correctly?
    Thanks :confused:
  2. Trollslayer
    Trollslayer
    Feb 11, 2007
    26,123
    Poole
    +10,963
    Just use what you prefer, there aren't any rules.
  3. 147jk
    147jk
    Jan 28, 2009
    19
    Maybe a misunderstanding.. I don't have control over the source; I'm using an OTA antenna. The stations broadcasting 720p look much worse than those broadcasting 1080i. The thing I don't get is how my older Philips could produce the same outstanding image on either one, while my brand new Panasonic cannot. Philips has the "Pixel Plus" feature.. is that what's doing it?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Does 1080i look better on the Panny than it did on the philips?
  5. 147jk
    147jk
    Jan 28, 2009
    19
    About the same - both just outstanding. But the Panny seems to need a 1080i source to do the same thing as the Philips does with a 720p source. This can't be true - I must have some setting wrong, but I can't find it.
  6. Pulse1
    Pulse1
    Nov 12, 2006
    2,951
    103
    Falkirk
    +257
    The px80 upscales everything to 1080p then it gets downscaled to 768p as that's it's native resolution. That's why 1080i is better than 720p :smashin:
  7. 147jk
    147jk
    Jan 28, 2009
    19
    OK, lets see if I understand this.
    The picture is losing clarity due to its being converted twice? If it didn't upscale, then downscale, the 720p signal would look better, as it does on the Philips, which I assume does not try to convert? I wonder if I can override it so it doesn't perform the conversions?
  8. 147jk
    147jk
    Jan 28, 2009
    19
    I am not able to override the upscaling. Hmmmm.. does this mean that for those of us who watch 720p TV on a set with a native resolution other than 720 will be left with compromised picture quality?
    So the only way to see an untouched 720p picture is to buy a TV with 720 native resolution?
    Disappointing :(
  9. rewerb
    rewerb
    Feb 29, 2008
    4,448
    +639
    I notice you're using a USA model and their OTA HD broadcast. We dont have that set here in the UK and we only get HD over cable or satellite. I have the PX80 and when it's fed 720p or 1080i showing the same program (changing the output of the cable box) I am really unable to see little if any difference of PQ, though some people say 720p is best!
  10. 147jk
    147jk
    Jan 28, 2009
    19
    I just can't believe Panasonic would sell a brand new plasma TV that cannot handle a 720p signal properly - that's the first thing it should do! I'm going to take it back and exchange it. Maybe there is something wrong with it (but I doubt it).
  11. Gromit
    Gromit
    Nov 30, 2004
    524
    Copenhagen
    +42
    Direct source is always the best.
    720p direct to a 720p TV (e.g PX80) is better than 1080i to 720p TV.
  12. 147jk
    147jk
    Jan 28, 2009
    19
    Yes that makes sense, but what I don't understand is why this TV up-scales to 1080 when it's native resolution is less than that. Why wouldn't it up-scale to its native resolution and stop there? The further up-scaling is (apparently) spoiling an otherwise good picture.
  13. Pulse1
    Pulse1
    Nov 12, 2006
    2,951
    103
    Falkirk
    +257
    The 42inch model is not 720p it's 768p native resolution so everything is output at 768p whether it be fed 720p/1080i or 1080p and as everything is upscaled to 1080p then downscaled to 768p i would say 1080i would produce the best and smoothest image. But always go with your own eyes as some people will see 720p as the better image :smashin:
  14. snig300
    snig300
    Jan 4, 2009
    877
    28
    +42
    panasonic told a forum member that they put the same chip in most of their tvs to keep the cost down!:eek: so a 720/768 tv will have a 1080 chip in it so will need to be upscaled first then down scaled,yesterday i tried a test with my bd player,I turned down all stuff like 24p,hdmi cable setting to standard from enhanced,1080 to the lowest setting etc everything to its lowest setting and i couldnt tell the differance! so im left with the feeling that ive wasted alot of money buying good hdmi cables,a good BD player,scart leads etc just to have the tv step in at the last minute to downscale all the good work that the BD player has done to a standard down scale of the picture!:mad:
  15. alffjeld
    alffjeld
    Jan 7, 2009
    103
    +10
    well thats the thing with buying a hd-ready tv, and not a full-hd.
  16. snig300
    snig300
    Jan 4, 2009
    877
    28
    +42
    i think your sound bite has missed the point i was making:lesson:
  17. 147jk
    147jk
    Jan 28, 2009
    19
    Yes 1080i/720p - both can be crystal clear, that is OK with me, but this TV appears to upscale a 720p source to 1080 (losing it's resolution), then downscales it. And this is done because of the chip used? To save money? I think I'll return the thing today.
  18. 147jk
    147jk
    Jan 28, 2009
    19
    What do you use for the run from your cable box to the TV? Coax cable, or other?
  19. rewerb
    rewerb
    Feb 29, 2008
    4,448
    +639
    hdmi
  20. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    I'm not really sure what you're saying here.
    Firstly, 10 seconds of google would have told you that spending money on HDMI cables is a mug's game.
    Secondly. 24p has nothing to do with picture quality but rather judder.
    Thirdly, how does the quality of SCART cables affect the bluray PQ?
    What is "enhanced" supposed to do?
    And I'm personally totally unconvinced that a "good" BD player will give a justifiably better picture than a £150 Samsung.
    As for the OP - I'm a bit surprised that 720p looks that much worse - are you sure it's not just that the 720p channels are compressed harder and on the smaller Philips, it wasn't as noticeable? I'd expect 720p->1080p->768p to soften the picture a bit but not to the point it's worth taking it back.
  21. 147jk
    147jk
    Jan 28, 2009
    19
    Yes it's possible I was looking at the same thing compressed onto a smaller screen, although I'd swear a 720p signal on that Philips looked every bit as good as 1080i does on the Panasonic. Unfortunately, the Philips broke after 3 weeks of use :rolleyes: so I can't go back a check it again.
  22. snig300
    snig300
    Jan 4, 2009
    877
    28
    +42
    chaddo2006 I get the feeling I've upset you!
    I've seen what has been said about hdmi leads and yes I agree you dont need to spend lots on one but a cheap 1 will affect the PQ and I would say 24p 100% affects the PQ as well, its deffo dosnt affect the sound!and on my BD player is the option for standard or enhanced hdmi input I dont know if that make a differance but as panasonic make a living from the stuff they make I would say they know more about what affects the PQ than me, and yes I did say I did a BD player test but went on to talk about the tv scaling and so a SCART would affect PQ again, much more than a hdmi lead would! I dont understand why you needed to reply to my post in such a way and without any helpful comments.
  23. xit2050
    xit2050
    Aug 20, 2006
    4,917
    Belgium
    +509
    No, it won't.
    :rolleyes:
  24. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    You have now you've spelt my silly nickname wrong ;)
    A cheap lead, especially if it's short, under 2m, won't have any effect on PQ (unless it's faulty which can happen with cheap leads... in which case you'll get very obvious sparklies all over the picture).
    If you count the removal of 3:2 judder as an improvement in picture quality, then yes, 24p will affect it. It has nothing to do with any other aspect of PQ though.
  25. Curry Monster
    Curry Monster
    May 18, 2005
    5,455
    +258
    This is correct -as has been said before aslong as the lead is not faulty then the digital signal will be passed with no loss of quality.
    Only people who shop in comet/currys will be swayed by £50+ hdmi cables - it is a nonsense
  26. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Sorry, missed this bit. I was just trying to help people who might read your post and take your observations as proof that no matter what kit you get, you end up with the same picture. Apologies if it came across as snarky.
  27. MZan
    MZan
    Dec 7, 2008
    139
    +11
    I have found 720p to be sharper than 1080i, unsurprisingly.
  28. 147jk
    147jk
    Jan 28, 2009
    19
    Yes, exactly. In addition, this Panasonic TV is sold specifically as a 720p TV, not as a 1080. So, that would lead one to figure it should produce it's very best image on an uncompressed, 720p, over-the-air signal. But that signal produces it's WORST image. I'm starting to wonder if something is wrong with this particular unit.
  29. snig300
    snig300
    Jan 4, 2009
    877
    28
    +42
    remember tho it scales up to 1080 then down to 720 so i would think the pq would suffer.
  30. Pulse1
    Pulse1
    Nov 12, 2006
    2,951
    103
    Falkirk
    +257
    Lol Guys, The 42inch is not a 720p resolution display it's a 768p native resolution display :rolleyes: so everything get's output at 768p even if 720p/1080i 60/1080p/24/60/50 is input to this display. The trick is to use as less upscaling as possible for the sharpest/smoothest image :thumbsup:
