Quantcast
1075 problem
Stereo Steve
My Rotel 1075 has suffered a heavy knock and now the 2 right channels don't work. The lefts and centre work fine.
Any ideas? I'm assuming it must be a fault on the right input section as I thought the actual amps were seperate.
Anything I should check?
booktrunk
Maybe the fuses have blown on these two channels. If you are brave enough to take the top off and take a peek at the fuses then you could find out one way or another.
I don't know if this would mess up any warranty. But when I had a 1075 it blew a fuse (well a couple of channels stopped working) and we swapped the fuses and it was fine afterwards.
Maybe phone B&W as they are importers for Rotel in UK and get them to put you through to Rotel support, and see what they say.
Steff
Stereo Steve
Thanks, I've already had the top off.:D
Are the fuses easy to get to and easy to see if they have blown? Also, what type are they and do I need to get them from anywhere special?
I guess one could be dislodged if it's had a bump.
booktrunk
Arrgh yes easy to spot and to replace... Check what they say on them.
I got replacements from Maplins either order online or get from a lcoal store. I really cannot remember the strength will ahve to check online I was thinking something like 6.3a "slow-blow" or "time-lag" whatever you want to call them.
Sorry got that wrong, these were for a RMB 991 not a 1075 so might be different strength for the 1075. So check the 1075 I would guess they might be a bit smaller.
But you will have no trouble spotting the fuses.
Steff
Stereo Steve
THanks again. I think I have found the problem though. I took the top off again and the rear input connector has 2 gold legs which attatch it to the board. These have been snapped off their solder points.
Looks like a simple repair for someone able. I'm not going to do it myself as I'm not confident enough with the soldering iron.
Any idea who would repair such a thing? I guess I'll get hold of B&W for further advice.
Bit of a releif though if that's the only damage.
booktrunk
Contact details for Rotel are:-
Rotel Europe
Dale Road
Worthing
West Sussex
BN11 2BH
01903 221763
E-mail: [email protected]
I'd try phoning them, they might know someone closer to you that would do it so you don't have to send it off, as postage on a 1075 won't be cheap :)
Steff
mjn
any decent electrical engineer could perform a task like that.
Try www.maydale.co.uk
I know the guy personally, and can fix anything from the board up.
witters
Steve,
I suggest from a cost point of view that you find a local electronics repair shop. They will be well capable of the repair and about 1/3 of the price of an authorised dealer!
Stereo Steve
Yeah, well I'm figuring in my part of the world the local electrical shop may well be the authorised repairer. I think it needs a new part that's all. The actual legs on the socket are broken clean off and I don't fancy someone thinking a bit of wire will do. I would also like it to be given a quick check over to make sure nothing else has been damaged.
Similar threads
