105kbsAT3 vs other rates
Discussion in 'Headphones, Earphones & Portable Music' started by sulk, Sep 2, 2005.
  1. sulk
    sulk
    Aug 27, 2005
    42
    I was looking at the settings in SS for transfering music, and I've decided to switch from transfering straight mp3s to atrac. The mp3s that I transfer are usually areound 192kbs~, so I'm not sure. Atrac at 66kbs is equal to 128kbs mp3. So i would think that 105kbs would equal to around 192kbs~ on a mp3. Anyone have any suggestions? Or know of a different rate to transfer at? Thanks
    -Sulk
  2. shadowritten
    shadowritten
    I'm quite happy with 64kbps (ATRAC3Plus, so better compression - valuable if your CD collection is vast!). This is supposed to sound as good as MP3 128kbps, and IMO, it does. I can only imagine, therefore, that either 105kbps or 132kpbs would give you the equivalent quality.
    Incidentally, if you have SS 3.2, isn't it possible now to use 192kbps?
  3. johnalkateb
    johnalkateb
    Aug 12, 2005
    3
    +9
    It is indeed possiable to have Atrac3+ at 192Kbps as its what i am using for my entier music collection. Brilliant quality i must say.
  4. shadowritten
    shadowritten
    Thought so. And that's supported by the HD5, yes?
  5. drmoze
    drmoze
    Aug 8, 2005
    196
    Yup. I'm doing my rather extensive cd collection at 192 as well. I will occasionally hook up my HD5 to a stereo, so the quality needs to be there and ripping at 64 kbps wouldn't cut it.
  6. shadowritten
    shadowritten
    Just noticed on Sony's site that they've dropped ATRAC3 105 and 66kbps from SS 3.2 onwards ...
  7. sulk
    sulk
    Aug 27, 2005
    42
    Ah, kk thanks I'll be using 192 from now on then, since they stopped using 105 from now. Thanks again for the info.
    -Sulk
