1024 x 720 plasma display will it work
Discussion in 'Desktop & Laptop Computers Forum' started by djcla, Mar 16, 2006.
  1. djcla
    djcla
    Nov 27, 2005
    7,629
    3
    Gloucestershire
    +601
    and show HD media files via a media PC? Will I get a widescreen resolution from the PC etc.?
  2. djcla
    djcla
    Nov 27, 2005
    7,629
    3
    Gloucestershire
    +601
    anyone?
  3. ChrisOH
    ChrisOH
    Apr 1, 2005
    402
    Cardiff
    +7
    Yes I think you will. But if you want more help then you might want to provide a litttle information about what you are trying to achieve and how.
    Chris
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    As with most things 'media pc', you might if everything works. You will need a reasonable level of pc literacy to get everything looking ok, and of course unless we have your screen and pc hardware, we can't give a definitive answer.
  5. djcla
    djcla
    Nov 27, 2005
    7,629
    3
    Gloucestershire
    +601
    Looking at the panasonic 37" px60 and before I buy wanted to make sure i could connect a media PC to it which I have not brought yet...
  6. Rambles
    Rambles
    Jul 14, 2004
    10,319
    167
    UK
    +2,086
    The nvidia drivers will allow you to select 1024 x 720 as a custom resolution, so providing the panel accepts that via a VGA/DVI/HDMI input you should get 1:1 pixel mapping OK and no reason why it shouldn't produce very good results.
  7. avanzato
    avanzato
    Jan 21, 2003
    1,970
    Norfolk
    +83
    1024 x 720 is an unusual resolution that I don't see in my ATI list of extended resolutions. Also it nearly 4:3 so you'll probably end up with the rectangular pixels problem in Windows, ie. the PC's pixels are square and the Plasma has rectangular pixels.
  8. djcla
    djcla
    Nov 27, 2005
    7,629
    3
    Gloucestershire
    +601
    Anyone got any experience with the 37" PV500 ?
