100x5R speaker terminals
Discussion in 'AV Receivers & Amplifiers' started by simon69, Mar 14, 2005.
Tags:
  1. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    Hi, do the speaker terminals take banana plugs or are they only designed for the 10mm spade connectors?
  2. muellec3
    muellec3
    Jun 10, 2004
    42
    Switzerland
    +3
    Hi Simon
    They accept banana plugs and spades; and also bare wire if needed.
    Chris
  3. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    Thanks for your speady response, no hefty bills for new ends then :clap:
  4. muellec3
    muellec3
    Jun 10, 2004
    42
    Switzerland
    +3
    ...you gotta remove the plastic thingies first though...:smashin:
  5. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    I also think you will find that the posts are 8mm, unless they altered them.....
  6. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    At the risk of sounding stupid, I would guess that the banana plugs on my cables are 4mm. I have not seen any 8mm plugs after a quick browse on the web. I suppose I would have to go back to the shop for them redoing!
    Can anyone confirm the size for me please?
  7. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    For clarity 8mm spades or 4mm banana plugs.
  8. Burgy100
    Burgy100
    Apr 20, 2004
    137
    Bedfordshire, England
    Hi Simon69
    I currently use QED Quinex banana plugs on my 100x5r. You remove the clamps completly to expose all the terminal post. You will find these are hollow and its there you can feed in the plugs, they will be a snug fit!!
    Steve
  9. roversd1
    roversd1
    I have, somewhere, the original gold plated copper terminals lying around somewhere...
  10. laalves
    laalves
    Feb 6, 2005
    529
    Cascais
    +8
    Stealing the thread, is it possible to bridge any two channels in a 100x5R?
    At the price they are going now, buying two of them and bridging some of the channels would be cool........
    Luis
  11. Tantalus
    Tantalus
    Aug 21, 2003
    289
    Aberdeen
    +3
    Nordost Z plugs fit in VERY snugly and seem like a great fit.
  12. roversd1
    roversd1
    You cannot and must not bridge any 100x5R channels unless they are the module specifically designed to do so (2x80w modules). Doing so would do considerable harm to the amplifier.
  13. laalves
    laalves
    Feb 6, 2005
    529
    Cascais
    +8
    Well, the thought of shunting terminals never ocurred to me, of course :) :nono: :nono: :nono: ...... I was wondering if it would be possible to internally bridge the modules, with a proper modification.
    Luis
  14. simon69
    simon69
    Jan 24, 2002
    508
    Leeds
    +31
    Thanks for all your help, this is why forums work so well, someone always knows something cheers to everyone!
  15. roversd1
    roversd1
    the 100x5R cant be bridged internally, externally or etherially
