100x5R resetting
Discussion in 'TAG McLaren Audio Owners' Forum' started by cj, Jul 13, 2004.
  1. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    I've noticed this a couple of times - one of the 5 LEDs flashes and then the amp resets itself. It's the same LED each time. It doesn't happen a lot, and not even when I've been driving the amp very hard. Could this be a possible connection or speaker problem?
    Thanks,
    Colin
  2. babaroga
    babaroga
    Aug 27, 2003
    220
    Hertfordshire
    +4
    I had simillar problem originally.
    Make sure that you have 100x5r with latest firmware and same applies to av32r and the problem should go away...
  3. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    It could be the amp protection circuit cutting in for various reasons, talk to the helpdesk......
    Checking the leads and plugs is a good idea in any case......
  4. roversd1
    roversd1
    Upgrading to the latest software version for the 100x5R will improve the software protection circuit .
    However, as Grahame suggests, check out you cables and connections first.
  5. Laingy
    Laingy
    Mine did it when pushing higher volume into one of the speakers, it turned out to be a slightly lose connection, adter resolving that it hasnt happened again.
