100x5R reliability
Discussion in 'TAG McLaren Audio Owners' Forum' started by cj, Oct 11, 2004.
  1. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Do these amps have any know reliability problems? I ask because my own has now "lost" 2 channels - one just shuts the amp down whenever I connect it to a speaker, and the other just doesn't produce any sound what so ever. I use it for my 4 rear channels, so am now 1 channel short :(
    And this coupled with my AV32R DP showing "Error - no Tag Sync Link" whenever I play a CD.
    I'm a bit loath to send them in at the moment as I don't wish to be without for 6-8 weeks... :mad:
  2. Pooley
    Pooley
    I've had a 100x5R for over 3 years and never had a problem with it. Sometimes during storms or if there's a brief powercut, the unit resets and some of the channels don't come back on. Just powering off, removing the mains lead and then reinserting the lead and powering back on restores all the channels. Strangely, you have to unplug the mains lead for this to work, just powering off and on using the switch on the front doesn't seem to work.
    Have you tried fully unplugging the unit and then plugging back in and switching on?
  3. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
    So far no problems.
  4. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    I've not tried that - will give it a go. Thanks for the tip.
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    CJ, Pooleys experience is just like mine, the unit has proved to be highly reliable in operation. Turning the mains switch off will kill the five channels but not the standby transformer with all the circuitry that controls / monitors the five channels. Un plug the mains and leave for 30 secs, then plug in again and the system will ‘do a full reset'. The original fault may be something as simple as a glitch on the mains at which point it will protect itself. This will sort it generally.
  6. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Thanks guys - pulled the power for about a minute tried again but no luck. Looks like I'll have to bite the bullet and send it in :(
  7. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
    Cj, have you managed to contact the helpdesk succesfully? For 2 days that I get bounced e-mails…
  8. Pooley
    Pooley
    Definitely sounds like you have a fault with the unit. Bit surprised with this, as I thought the amps to be pretty bullet-proof with all that built in protection.
    At least you can get the other amp modules serviced and have the latest firmware installed when you send it in.
  9. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Sent an email in but no reply yet - I will phone them today.
  10. TaxHamster
    TaxHamster
    Jul 8, 2004
    39
    11
    +11
    IAG are currently experiencing extensive email "difficulties", I'd suggest resorting to the telephone for contact.
    Hope this helps...
  11. RuiGil
    RuiGil
    Hello, this is my first contribution at the AV Forums, so please be patient.
    Two weeks ago I bought a brand new 100x5r. After instaling it, I've noticed that module 2 didn't work, although the led was on and everything seemed OK. I checked the connections twice and everything was OK. Meanwhile I've noticed that, when configuring the amplifier throught the Av32r DP, in the menu where you assign the modules to the channels (R, L, C, SR, SL), there wasn't a relay click when I selected module two (SL), so I took the amplifier to the Portuguese representative.
    Yesterday they delivered the amplifier to me and said that the fault was caused by an internal fuse. Explained to me that these fuses are installed before each one of the controlling relays (at the control board) that control each one of the channels. So they replaced all the fuses by more tolerant ones, as they usually do.
    So as a conclusion, and only if you have the minimal skills related to electronics, after disconnecting the power cord and all other connections, check if any of this fuses are burned. If it is burned, replace it by a similar one. If it burns again, don't try to replace it again, your amplifier module is dead and the amplifier must go for IAG. If not, enjoy it.
    Hope this helps.
    PS: Beware that you should know what you're doing, otherwise sent it to IAG.
  12. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    Thanks RuiGil and welcome to the forums :)
    This is exactly what mine does (or doesn't do) on module 3 - is the fuse easy to spot? Anyone know which replacement fuse I might need?
  13. cj
    cj
    Apr 6, 2001
    1,457
    Reading
    +74
    No one got any 'fuse' tips? My screwdriver is getting restless...
  14. Pooley
    Pooley
    Depends if your amp is still under warranty. If it isn't, then there's nothing to stop you taking the cover off and going to work with a continuity tester to try and find the fault. At least a fuse should be easy to spot.
    Please be careful if you decide to do this. There's bound to be capacitors in these things that would hold a charge for some time. I suggest you only have a go at this if you know what you're doing and have the proper kit. Me, I'd get a competent mate with knowledge of electrical systems to do it. Your choice....
