Losangelgab
Hi, Could anyone advise me which amp to go for and the relative pros and cons? I am looking to partner with the av32r 7.1 and a dvd32r. Thanks.
Nic Rhodes said:I clock my 100x5r at over 150w x 5, it was very conservatively spec'd. I think just shy of 155w, bt I could be measuring it wrong![]()
Stevesky said:Well, it all depends how you measure your watts!![]()
the 7.1 feature is very usefull and it `s worth giving it a try as long as you can use movies encoded with dd/ex and combining it with thx ex surround feature from the av32 bp /ex...besides that the 7.1 formation still gives more ambient and space dimension even when used without the thx ex or even when it is been used with material with simple dd or dts encoding...but as i said it`s better with the thx ultra specification...austingabriel said:I have Calliopes + base modules front, calliope centre plus calliopes rear. I don't know if it's worth utilising the 7.1 feature of my av32r or even which extra speakers I should use. Will the 100 x5r be significantly better than the 700:7r with this set up. Many thanks.
