hairybaboon
Hello and thank you in advance for any help
I would like to install an intergrated sound system in the downstairs of my house. I have already purchased a 120W Astrada amp with Bluetooth capability, so I can easily transmit my playlist.
The total run length I imagine is 100-150m. Between 5 rooms I wish to have 9-10 speakers. I aim to have a suitable attenuator to control the volume while the receiver is hidden away in a cupboard.
I can buy these for a good deal (I think) at £50 for 4 units, so I will buy 2-3 sets. Are these good quality or should I spend a little more? I want a nice quality sound for background... It doesn't have to be nightclub loud.
4 x Bosch LHM0606/10 6W 100V Line Ceiling Speakers
Would you recomend a particular cable also. I have some 0.75mm double shielded cable but am worried the length or run and number of speakers may render this diameter wire unsuitable.
Appart from the ceiling speakers, which come with the transformer, possibly new wire and the attenuator. Is there anything else I need to purchase or you can advise I get to complete my system?
Many thanks
Nick
Many thanks
Nick
