100M USB Bluetooth Dongles
Discussion in 'Desktop & Laptop Computers Forum' started by Crocodile, Nov 17, 2004.
  1. Crocodile
    Crocodile
    Nov 4, 2002
    18,325
    +6,858
    Are they any good & is the range anything like the 100M quoted? The few reviews I've found suggest that they're pigs to set up & have a range approx 6 inches greater than IRDA. I want to sync my PDA (iPaq 2210) via Bluetooth.
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    I wouldn't think the iPaq had a range anywhere near 100m, and as it is a 2 way street, i would imagine your range being limited by the iPaq rather than the BT dongle. if you're looking for distance wifi might be more appropriate? althought clearly you'll have to buy more stuff to do that.
