100Hz TVs - 'Jaggies'
Discussion in 'General TV Discussions Forum' started by harmunt, Dec 11, 2003.
  1. harmunt
    harmunt
    Jul 26, 2003
    181
    Are these inherent to all 100Hz sets?
    I have a Loewe Aventos (my second one!) and at times the jaggies are shocking.
    They are much more visible on Sky Digital, but are also present, to a lesser extent, on video games and DVDs.
  2. Nana
    Nana
    Have you got the scart put in via av3? Apparantly that is the correct option if you have RGB as the others are composite or sv only.
  3. harmunt
    harmunt
    Jul 26, 2003
    181
    Incorrect.
    Both Scart 2 & 3 are RGB enabled.
    And, yes. All my gear is through the RGB settings.
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,290
    United Kingdom
    +1,571
    The "jaggies" will appear on any TV that doesn't have a Progressive Scan Mode or isn't capable of receiving a Progressive Scan signal from a suitably equipped dvd player. Even then, some TV's PS mode doesn't eliminate all "jaggies".
  5. Nana
    Nana
    Apologies, I read on this thread "pixelation on loewe aventos" by Paperboy that a few people were using AV1 etc which isn't RGB enabled and were having problems.
  6. Dog-rat
    Dog-rat
    Whats the "Jaggies" ? :)
  7. S H A D O
    S H A D O
    Mar 16, 2001
    10,290
    United Kingdom
    +1,571
    Straight lines are jagged instead of straight, curves are stair-stepped etc. Most notable example would be when watching a football match, all the pitch lines look like stairsteps. With a progressive scan tv/dvd player they are all straight and the centre circle is curved.:)
  8. Dog-rat
    Dog-rat
    Jase
