100hz hmmm
Discussion in 'LCD & LED LCD TVs Forum' started by Bob Todd, Sep 14, 2007.
Tags:
  1. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    From my POV it appears most of you guys cream for it, but then when you spend the extra few hundred quid for it, many of you complain it causes more visual flaws then it solves.
    is it really worth it on an LCD or is the technology not refined enough yet?
  2. fxytimi
    fxytimi
    Apr 2, 2007
    157
    +9
    its worth it, it use will actually use it to your advantage for example gaming and fast moving motion, i haven't seen any motion blur with my lxd70 none at all. so im happy.
  3. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    I have seen many tv's with 100Hz and without.So there is definitely BIG IMPROVEMENT on fast moving scenes,sportsetc.
  4. CHFels
    CHFels
    Feb 20, 2007
    495
    +42
    The complaints mainly concern watching DVDs or HD discs, they say the motion interpolation spoils the "cinematic" feel of the movie. I haven't experienced it, b/c I have a plasma, but I *have* seen what motion blur on an LCD is like (in stores), and it's worth it to have a gizmo that gets rid of (most of) it if possible.
    CHFels
  5. davejm
    davejm
    Jun 29, 2007
    188
    +15
    I think the majority of people are happy that the 100hz processing feature is here. It's generally agreed that the technology works to a certain extent, but it's still in it's infancy. As CHFels mentioned, there are downsides to it at the moment and it isn't a perfect solution.
  6. hamster
    hamster
    Oct 25, 2005
    472
    28
    +29
    Most of the sets out there use a Micronas IC that only does horizontal motion and does the frame interpolation seemingly with SD frames inserted. It also gets a bit pushed when there's a lot of motion. The IFA demos from most setmakers were very careful to use quite undemanding content.
    There are some awesome chips in the pipeline from a number of suppliers which will be out in 2008 which interpolate in HD, and can handle motion in all axes. If your set hasn't actually popped, then I'd be tempted to wait as it's a field that's developing extremely rapidly.
