100HZ Gun for PS2?
Discussion in 'Playstation Forums' started by Jase D, Feb 11, 2002.
  1. Jase D
    Jase D
    Someone mentioned to me that there is a light gun coming out for the Playstation 2 which will work on 100HZ's widescreen tv's, does anybody know if this is true? If so where can i get one from?
    If this is not the case does anybody know if there is a way of getting them to work. I have a Toshiba 32 ZD98DB Television.
    Jase
  2. John Jennings
    John Jennings
    Aug 7, 2001
    282
    Uppsala, Sweden
    +5
    AFAIK Namco's G-Con2 gun works fine on 100Hz tellys. It only works with PS2 games that support it though, so you can't go back and load PSone Time Crisis, Point Blank etc and use it on them though.
