100 inch projector screen recommendations?
Discussion in 'Projectors, Screens & Video Processors' started by neilbart10, Jul 15, 2015.
  1. neilbart10
    neilbart10
    Dec 24, 2013
    10
    Hi there
    I am looking to buy a 100 inch fixed screen for my Benq 1070.
    My budget is around £250 I have seen a couple of screens by Elite and Luxburg are these decent it does anyone have any other suggestions?
  2. kbfern
    kbfern
    Aug 17, 2002
    17,938
    Wolverhampton
    +6,099
    Make your own from about £50.
  3. neilbart10
    neilbart10
    Dec 24, 2013
    10
    Thanks but you have obviously never seen my DIY skills! I did think about it and researched some fabric from Projector Screen Material. Com but it appears that if using wood it eventually warps etc
  4. ShanePJ
    ShanePJ
    Well-known Member AVForums Sponsor
    Jun 20, 2006
    2,804
    Unit 5 The Sidings, Bacup, Lancs, OL13 9RW
    +726
    If its a cost thing then many dealers offer the option of finance (Buy Now Pay Later) and if you're placing 50% upfront then you will have twelve months to pay the remainder of the screen off.
    The AMLETO 102 Fixed Frame Projection Screen is one such screen which will give you the quality to bring best out of your projector. There are others available.
    Regards, Shane.
  5. neilbart10
    neilbart10
    Dec 24, 2013
    10
    Thanks Shane will give this a look.
