100 hz - what to look for
Discussion in 'General TV Discussions Forum' started by keyser, Jun 30, 2002.
  1. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    What side effects should I look for on a 100hz TV - one is smearing of fast moving objects, are any sources better than others for spotting this, I´d imagine a snooker match would be good. And also what should problems should I watch out for on the Toshiba TV´s, heard some talk of black bars and dirty screen whatever that means
  2. bob007
    bob007
    Don't think there's any snooker on at the moment, though Pot Black has just started again :( how about tennis, wait for a Creg Rusedski match and if the ball don't smear nothing will. :D
    The side effects (including smearing) of 100hz sets are the broadcasts themselves or having to many of the sets digital enhancements on, DNR being one of them, this set to max will give dreadful pictures. It's not the side effects of the 100hz you should really be looking for but other major faults that many of the sets have through sloppy quality control.
    Good Luck
    Bob
  3. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    Another problem to look out for is bad color resolution - this is mostly visible with video games. It's common for 100Hz processing to heavily downsample the color, so to make the data fit into relatively small memories. A side effect is that even with RGB signals, the color is never as sharp as on an analog 50Hz set.
  4. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Yeah, thats one of the things I noticed at the store, the 50hz set had much sharper coulours... thought maybe they just messed up the settings. If I have a 50hz set, does then a ntsc 60hz picture get converted to 50hz?
