100 Hz TV Compatible with Multiregion dvd?
Discussion in 'TVs' started by happysnapper, Jul 26, 2004.
  1. happysnapper
    happysnapper
    I am looking for some advice as pretty much a novice.
    I have a multiregion dvd player connected to a goodmans 28" nicam stereo by scart (the tv is not widescreen). Currently I can watch all my Region 1 and 3 dvds fine.
    I want to upgrade to a widescreen tv. I've seen a samsung w/screen 100 Hz tv:
    1> Will this be ok for my region 1 and 3 dvds through my current dvd player? 2>If it isn't ok can you get a convertor that would make it possible?
    I've looked on the net and can't find anything to say whether it is NTSC compatible.
    I assume if my old tv was ok (and it is at least 3 years old now) the newer tv will be fine (as its more advanced). I just don't want to shell out 400-500 quid and then not be able to watch some of my movies.
    Would appreciate any help.
  2. Moo242
    Moo242
    You'll have no problems whatsoever playing NTSC DVD's through this telly
  3. brummybloke
    brummybloke
    Jul 18, 2004
    85
    as i understand it, if it has a scart lead then it will play ntsc as scart is universal, although if you want to watch in colour you will need an rgb scart lead ( true for ps2 so im guessing also true for dvd?)
  4. happysnapper
    happysnapper
    I appreciate the help.
    Thanks guys
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Not true of most DVD players.
