100 Hz test
Discussion in 'LCD & LED LCD TVs Forum' started by butterflies, Jan 25, 2008.
Tags:
  1. butterflies
    butterflies
    I have a 37 Z3030 Toshiba and cannot find a proper way to see 100 Hz working. I have a faint feeling that it doesn't work on my set.
    What is the best way wether this features works or not?
  2. Hoax
    Hoax
    Dec 11, 2007
    393
    +23
    scrolling letters or something like a pendulum ..
    google for burosch and you will find a german site you can download a free calibration/test dvd from there which has those things ..
    as an alternative you can find a news channel which has lots of scrolling text at the bottom
  3. Ollie C
    Ollie C
    Jan 18, 2008
    622
    +21
    Hi, I dont have a answer to your question but i am considering buying that tv,whats it like? do you have it connected to an xbox 360? if so whats the picture like as I have read reports of people having problems with certain colours on the 37X3030D & I wanted to know whether the problem is repeated on the 37Z.
    Have you sorted the 100hz problem?
    thanks
  4. Nielo TM
    Nielo TM
    Oct 30, 2005
    5,062
    LDN
    +549
    Only enable 100/120Hz processing on 50/60fps contents. So when viewing and playing contents thats are in 25 or 30fps, disable it.
