100% flat, 100 Hz widescreen ((multisystem broadcast)) television
Discussion in 'General TV Discussions Forum' started by silver_sam, Jul 26, 2001.
  1. silver_sam
    silver_sam
    Hello,
    Would anyone point out what 100% flat, 100 Hz widescreen television that support multisystem broadcast?
    I am looking for the telly supports PAL I in UK, PAL D in South East Asia as well as NTSC signal in the USA.
    I read somewhere (can't remember now) that some Loewe telly do support multisystem broadcast.
    cheers.
  2. Lowrider
    Lowrider
    As far as I know all new LOEWE support multisystem... as do other brands, at least the ones I looked...
  3. silver_sam
    silver_sam
    http://www.loewe.de/cda/frameset/0,2206,ge-en-fl11-0,00.html
    yup, it supports PAL D.
    (1) From the website,
    NTSC NTSC / NTSC (Video)
    means it supports
    1)NTSC --> broadcast
    2)NTSC (Video) ---> ie DVD or video signal.
    Am i correct?
    (2) Would anybody suggest me best price (where to get them) best model for Loewe 32' 100Hz telly?
    From earlier discussion I can assume Vitros is better than Aconda. Any other model superior than this?
    thanx
  4. Garrett
    Garrett
    Apr 21, 2001
    43,658
    2
    167
    The best thief you'll never see.
    +8,418
    Just looked in my tuner settings and my Aconda has the following
    Pal-60,M,N,DK,BG,L,I
    NTSC –V
    AUTO –V
    As far as I know Vitros uses the same innards as the Aconda, only the casing is different and cheaper.
    Try TV & Video Direct LTD 01204 39511, Empire also sells them (these are open late)and Kendals (or one of there other named branches) will generally sell you one with a free 5 year guarantee but you're likely to pay list price for the TV (no-good if you are moving abroad?)
    :cool: Ruby quartz shades
  5. Garrett
    Garrett
    Apr 21, 2001
    43,658
    2
    167
    +8,418
    Sorry as I pressed post, I noticed the telephone number was the fax number.
    This is the right one 01204 395999
    Has this site just been of off, tried to get this up 2mins after last post but was unable to get anything till now.
