10 meter long component cable for ptae100
Discussion in 'Projectors, Screens & Video Processors' started by kim@cheung1957., Apr 12, 2003.
  1. kim@cheung1957.
    kim@cheung1957.
    Where to buy 10meter long component cable for my ptae100, pl. advice the best deal. Thanks.
  2. nathan_silly
    nathan_silly
  3. originalbadboy
    originalbadboy
    Mar 27, 2003
    238
    +3
  4. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    I got a custom made one from vdc 3 cables joined togetther, right colour plugs on end - 45ish including delivery
  5. Rande
    Rande
    Apr 14, 2003
    Thanks. I was trying to find an affordable component cable - all the ones I could find before were twice the price.
    I'd moved the DVD player closer to the projector to avoid paying lots and lots for the cable.
  6. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,424
    Surrey. UK.
    +2,092
    I'm using that one as well - I also ordered a cheapy 5m one (blonggest in that range) for £5 to compare, and I can't see any difference, so for video, you don't need to spend a lot of money on cable.
    Gary.
  7. Monster
    Monster
    Oct 9, 2000
    974
    Adelaide
    +30
    I bought 30m of 75ohm Co-ax from Nexnix and soldered on thier own gold plated RCA's (£1-£2 each can't remember) Connected from DVD to TV, picture looks the same as 1m Ixos cable. Certainly no probs with the PJ.
  8. AVcontroller
    AVcontroller
    If you want value for money but high quality try the cables at intoav.com They make up the stuff BBC broadcast use for thier installs.
    A 10m custom made component , SVHS and composite set cost me £89 and its very good.
  9. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    I'm also interested in component cables but need 15m. Farnell only do 10m.
    Anyone know where to get 15m component cables from which are good but reasonably priced?
    Cheers,
    Cal.
  10. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
  11. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,870
    2
    167
    Birmingham, UK
    +9,614
    SVHS is a type of video tape. You mean S-Video.
  12. juboy
    juboy
    Try the guys at Scorpion Cables for decent quality component cables, which you'll need if you're running 10m+
  13. timlloyd
    timlloyd
    Jan 15, 2003
    278
    Warwick
    +9
  14. dejongj
    dejongj
  15. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Thanks Tim,
    Your tip seems to be the first for a 15m reasonably priced cable.
    There may be better cable out there from the other tips for about £150 but I think the 30 quid cable plus say a Yamaha prog scan dvd player for another £133 would improve my picture more.
    Cheers,
    Cal.
