10 foot lounge - 42 or 37 inch?
Discussion in 'Plasma TVs Forum' started by Stampax, Jul 1, 2005.
  1. Stampax
    Stampax
    May 6, 2005
    1,405
    Northampton
    +88
    My new house has a 10 foot lounge (as in from the wall i'd put the plasma to the wall id put th sofa) - so i guess when sitting down on the soaf this means it'll be a 8 footish viewing distance roughly.....
    Do you think 42 inch plasma would be too big?
  2. ash
    ash
    Jun 9, 2005
    11,221
    +395
    Bigger the better, no?
  3. av2diefor
    av2diefor
    I view a 505xde from 3m and its starting to look small.
    It cant be too big :smashin:
  4. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    8 ft ??
    Perfect!!!
    As long as you don't buy rubbish :smashin:
  5. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    i have a similar size lounge and thought 42" would be to big. i got a 37 but now sometimes think 42 would have been better
  6. neilios
    neilios
    Dec 18, 2004
    8,058
    Earth
    +3,971
    I actually sat and watched a sharp 45 lcd and a pio 50 xde from that distance showing hi def and it looked ace ,so get the biggest one you can.
  7. gur
    gur
    Nov 4, 2004
    104
    Definately go 42", it'll look huge for a week or so and then look surprisingly small. Until you visit a friend with a 28" crt :eek:
  8. rudy
    rudy
    Jan 2, 2005
    499
    Really? i think 37" is ok. A big telly in a small room is a bit chav innit
  9. rab4169
    rab4169
    Dec 12, 2004
    533
    well i just bought a 42" plasma for a room where i sit 10 foot back although it is not fitted yet. do what i did , step it out then do the same in shop to see what it looks like
  10. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Definately 42" - you will reget not buying one, its not as though they are thousands more expensive.
  11. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    42" from 8-9 foot away looks great in my current living room.
    John
  12. asimmd
    asimmd
    May 6, 2004
    518
    +11
    I was all set to get the 37in cos the Wife said 42 was to big,but now I've read this thread,I'm back to thinking 42 may be the way to go?
    The lounge is 13ft wide X 23ft long, and we sit about 10/12 ft from the screen,so I guess it will be OK.
    Alan
  13. ash
    ash
    Jun 9, 2005
    11,221
    +395
    Even 50" would be good! :smashin: :hiya:
  14. k0rn
    k0rn
    I would go with the 37".
    Going with the biggest isn´t always the best choice. It has to fit in the room and you have to be able to see the picture all at once without moving your eyes or even your head.
  15. batty
    batty
    Nov 22, 2004
    229
    Southampton
    +27
    :hiya: I am sitting 9' from my new 42pd7200 and it is great!
    Everyone who's seen is well impressed.
    go for 42" :smashin:
  16. Enquirer
    Enquirer
    Depends on..
    1 If you are an AV nut (like most here)and want to create a home cinema experience then bigger the better (you would never complain to the cinema manager that the screen is too big for the room ) if a plasma is installed properly and all the wires are hidden then a big plasma especially panel models can look tidier than a smaller all in one plasma set with wires showing
    2 If you want to have a designer looking home with a trendy flat screen but are more bothered about the overall look of the room and If you only watch a bit of telly and don't watch DVD films or sports there seems little point in getting a massive plasma.
    neither is right neither is wrong just horses for courses.
    I really feel a quality install of a panel only plasma can make the screen seem really small when switched off but give you the big screen many yearn for when you watch anything on it.
    a few years ago i fitted a 42 PW4 wall mounted with sound provided all round by KEF's in wall reference speakers which were painted the same colour as the walls All the components were hidden in a cupboard and were still remote controlable .This was a very discrete installation but it really performed. a 37" viera on a stand would have looked much bigger in the same room and with poorer sound BUT of course that sort of installation costs much more.
  17. dilsher
    dilsher
    Rudy
    Just by having a posh flat screen means you're a chav, innit mate??
    And more so if you is a Chelski "supporter"...
    I have a 12 foot lounge with a 50" PDP - looks great even at 3 feet.
  18. BIGMAX
    BIGMAX
    Jan 11, 2005
    746
    +18
    I sometimes wish I'd gone for the 50" but the you have to weigh up whether the extra cash is worth it. I sit around 9 feet away and the 43" seems perfect but would be interesting to see a 50".
    I think the choice between 37 or 42/43 is a no brainer - has to be 42/43 in the type of room suggested.
  19. MPK
    MPK
    Nov 26, 2004
    478
    London
    +8
    Check out this article. Looks like it should definitely be a 42" (or maybe a 50"? :D )
  20. thornton
    thornton
    Apr 18, 2005
    263
    +10
    I have a 37in in a similar room and am relieved I did not go for bigger. Unless they are really using a lot of bandwidth I spend a lot of time cursing the lack of detail in Freeview and SKY. This does not happen with DVDs and hopefully won't with HDTV. I think getting a standard def 42in set in such a room would be silly, unless you have really bad eyesight anyway!
  21. rudy
    rudy
    Jan 2, 2005
    499
    s'pose a 50" pdp is safer bet. Harder to lift!
    *adjusts Von Dutch cap*
