(1 X 3.3 Mega Pixel) vs (3 X 1.07 Mega Pixel CCD)
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by PRINCEGRINCH, Mar 17, 2005.
  1. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    679
    +7
    Sony DCR-HC1000E (3 x 1.07 Megapixels CCD) vs Sony DCR-HC90 (1 X 3.3 Megapixels Advanced HAD CCD)
    Can someone please explain to me what the difference would be between the two camcorders above would be, as one has a 1 CCD which is 3.3 Mega Pixel Chip and the other has 3 CCD Chips which are 1.07 Mega Pixel?
    Would there be a significant differnce? Would it be worth the extra £300 for the Sony DCR-HC1000?
    Also how would the 1 x 3.3 Mega Pixel Chip of the Sony DCR-HC90 Camcorder compare to that of Sony DCR-IP55 MicroMV Camcorder which has a 1 X 1.2 Mega Pixel Chip. IN TERMS OF LOW LIGHT PERFORMANCE as the DCR-IP55 is poor.
    I want to know whether its worth buying the Sony DCR-HC90 from a UK site for £550.
    One final question would it be worth buying a camcorder from Price Japan? What would the Power Supply & Format be like? Could I get an import Warranty for it in the UK?
  2. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,152
    Leicester
    +57
    I've looked at these 2 as well.
    The HC1000 uses 3 x CMOS chips, possibly to make it smaller. I would say it would be on a par with the HC90 but not better. I've also read than CMOS is not as good as CCD.
    I don't think the HC1000 is worth an extra £300.
    I will hopefully be getting the HC90 in the Summer, as it is easier to hold for me as well.
    I'm going to try and sell my Panasonic GX7 first though.
    Compare the 2 here
  3. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    679
    +7
    Thanks for the reply Wayne. I have two more questions, the first one being the most important:
    1) How well do you think the HC90 would perform in low-light as the IP55E MicroMV was very poor.
    2) Isn't comparing a 1 CCD Chip to 3 CCD Chips like comparing a Composite Video Signal to an RGB Signal? (Where 2 CCCD Chip is an S-Video)
  4. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,152
    Leicester
    +57
    1) Comparing the spec of the 2, the HC90 Lux rating is 5, before using Nightshot and the IP55 is 7 Lux. So I'd say the HC90 would be better. If the lighting is that bad, you may need a light.
    IP55E spec
    HC90 spec
    2) No. At this consumer price range, I'd say you won't notice a huge difference.
    Go for the HC90, it is fab and let me know how you get on. I had a go on one in Jessops and loved it.
  5. PRINCEGRINCH
    PRINCEGRINCH
    Oct 6, 2003
    679
    +7
    Thanks again Wayne for the help & advice. All I need to do now is find the best price for the Camcorder. So far the best I've found is £535 (£545 with delivery), but I'm going to pick it up from the shop so its £535 for me. I'll let you know how I get on with it, when I get it. :thumbsup:
  6. atmoscinema
    atmoscinema
    Aug 4, 2000
    2,152
    Leicester
    +57
    Great news.
    I had a Sony Digital 8 at first and that was great, so you'll be fine with Sony. It's being pushed as having professional results anyway.
    :thumbsup:
  7. cerebros
    cerebros
    Dec 27, 2002
    1,368
    48
    Leicester
    +44
    Is that just in terms of video or in general for imaging sensors? Can't imagine it's for all imaging sensors, otherwise Canon wouldn't have moved to using CMOS in all their DSLR's, but I don't know if there are any technicalities that would make it worse than CCD for video.
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,587
    Rainham Essex
    +2,541
  9. cerebros
    cerebros
    Dec 27, 2002
    1,368
    48
    Leicester
    +44
    Unfortunately i didn't find much of use there - only some additional links to some CMOS Vs CCD articles that are 3 years out of date and so haven't been updated to reflect that image noise isn't a problem with CMOS tech anymore, at least in stills cameras (otherwise pro photographers wouldn't be buying Canon's £5+ top end DSLR's), although I can't see why the same advances wouldn't apply to video sensors.
