1 wire left.... where does it go?
MrControversial
Hi all,
Just at the final stage of installing and I've stumbled at the last hurdle. Everything connected bar the ignition feed (marked A - red wire). The loom is a little different to my old one so can anyone tell me, from the pic below, if A goes into B or C? As you can see further up, A is cut into the feed before the connection block, I assume this is to bypass the ignition?
This is the last wire, then I just need to figure out if the ISO plug (X) needs to go in Y or Z.
Hope someone can help. Thanks in advance ;)
